Question about Acer Computers & Internet
Trying to install a clean version of vista on an acer aspire 5515 i boot from install disk then the screen say loading microsoft components ( or something) then it goes to the screen that says microsoft along the bottom and a bar beneath the letters thats impliess it is loading and thats it cant get any further. the whole reaon i want to put a clean version on is because i installed a sprint wireless card then restarted vista loads but the mouse and keyboard are froze. can you help
  • knemeth7479 Sep 23, 2009
    ok thanks will do one more question i know acers usually have an alt f10 option for acer d2d recovery when i try to access this a command propt pops up as if d2d is not there is there any way i can recovery that option, as well what are your suggestions on trying to get the mouse and key board to function on the currently installed operating system
  • Acer Master
  • 3,866 Answers
Okay if you have a stuck loading bar you might have a dirty disk or a bad cd/dvdrom Ether way there is something wrong here with the cd/dvd rom drive at this point or you got a dirty spot on the disk.
1. check and clean disk if there is dirt or scratches on it.
2. Check drive for integrity by running the acer diagnostics program from www.acer.com
There are only a few things to check otherwise I would bring this in for service if the above does not work there may also be problems with the hard disk itself but i cannot tell over email so I am giving you the following advice above.
Please do Accept and Rate the advice given you Thanks
Posted on Sep 23, 2009
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
I have aspire acer 5515 when turned on it sas operating system not found.... I have no boot diskd etc that came with the computer where can I obtain the disks to fix it....
Here is a site that will show you how to make a rescue disk (recovery console), for all windows OS's. Also has link to a very good free ISO burner. Burn to cd instead of dvd if possible.
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
Good luck
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Oct 30, 2010 | Acer Aspire 5315 Notebook
Acer aspire 6530 will not run windows vista, will not allow safe mode, just keeps loading files on screen then nothing! LOADED: :WINDOWS:SYSTEM32:DRIVERS:FILEINFO.SYS (loading files message but with a...
When your computer is first booting, try tapping F12 to get to the boot menu. Once there, boot from the Vista installation disk- you may need to fully reinstall windows from that point. Try doing a repair first- if that does not work, do a full reinstall.
Oct 03, 2010 | Acer Aspire 6530-5143 Notebook PC
Acer aspire 5515
you might use non genuine Windows Operating System upon installation. My suggestion is re install it, get everything set (internet browser etc) before surfing on the internet
Apr 10, 2010 | Acer Aspire 4520-5582 Notebook
Acer Aspire 5315 Vista Windows boot problem
have you checked if your pc is compatible with win7? use this to check it: http://www.microsoft.com/windows/compatibility/en-us/default.aspx
and if it is, try to do a clean install. boot from the cd. insert the disc. restart pc, as soon as it has power, press F12 several times and highlight cd/dvd drive or ODD using your arrow keys then press enter. it will load the cd from there. And that should work fine.
Apr 03, 2010 | Acer Aspire 5315 Notebook
Acer Aspire 5515 stopped responding and will only boot as far as the Microsoft loading screen
Try tapping the "f8"key when booting - it should allow you to choose "safe mode".
If it starts up - scan the PC for errors (including bad sectors on HDD)
If it still does not boot - I'd try booting from the windows install disc and use the installers repair console.
If that wouldn't help - I'd get a bootable CD of Ubuntu or some other OS and try and repair the windows installation from there.
Oct 23, 2009 | HP Compaq Presario R4000 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Blue screen wont boot from disk
This more often then not a memory problem. Chances are some kind of virus or malware has damaged your memory not allowing it to dump the temp files. You will need to replace one or both of the sticks. The other problem may be a faulty hard drive with a partition error.
Joe
May 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
Want to remove Win Vista and install Win XP on two computers
have or can you get a win 95/98 disk...
these disks utilize the dos enviroment...
when you boot with them you can easily get in the dos platform (c://prompt)
once there type in fdisk and follow instructions.
you can also do this from usb ..you need to make usb bootable first.
you may be able to use xp disk and choose repair which will take you to the dos prompt.
you may be able to format hd with vista disk and before it start to install files interrupt it(remove disk)
not advisable though.
if you want program to create bootable usb let me know.
I'll need youre email address to send via attachment.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
