Question about Sony CMT-ED1 Shelf System
Cd player missing piece that holds cd's in place, the piece i assume would be very similar to what hold the cd in a cd case....how do i fix that? where can i get replacement parts?
  • Anonymous Jun 23, 2015
    Thanks to aqghjser4 I did precisely what was suggested and bought the PlayStation 1's CD spindle hub on-line. I found that by removing the small pivot piece at the top of the assembly and placing it on the round CD play base on the Sony system it fits exactly and works just as it should! That is THE solution to a missing center pivot piece. Why the folks at Sony Repairs are not aware of this is a mystery to me since Sony makes both the shelf stereo system AND the PlayStation!!! Thanks!
3 Suggested Answers
SOURCE: cmt-ed1 sony
If you mean the CD spindle hub, not the stabiliser. Then you can buy the PlayStation 1's CD spindle hub  (plenty, just google with keyword ‘Playstation 1 spindle hub’ and you will see)  to replace it.
Just push in the new spindle hub, not too close, not too far, from the laser head.
I did, it worked.
Posted on Dec 17, 2008
  • 899 Answers
SOURCE: Odd scratching or grinding noise
that white piece sounds like the magnet that goes above the black little disk that holds the cd in place by the magnet wanting to connect to the top of the cd holder and motor (the magnet presses the disk on the holder to prevent slipping )
need anymore help?
Posted on Oct 18, 2008
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Can you manually release a DVD from the Panasonic S32? The DVD player 'died' - with a CD inside. The instructions are silent on a manual solution.
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!!
Apr 01, 2010 | Panasonic Televison & Video
Center hub won`t stay up to receive 45`s on wurlitzer 3600.
The centre hub is pushed back upwards after a record is replaced. If the mechanism is jammed or a bit missing it won't reset. What holds it in place once reset is three small spring loaded prongs (assuming I am imagining the right machine) around the edge of the centre hub. Check they are not gummed up.
Mar 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
CD/DVD drawer won't open so CD stuck inside :(
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Disk is stuck in a multi-disk CD player. How do
You didn't specify the make and model of the unit you have, but I can give you some basic steps that should help you resolve the problem based on past experience with other similar units.
First unplug the unit. Then remove the screws that hold the cover on the unit. Remove the cover. Any CDs that are not in their holding places that may have fallen into the unit, reach in carefully and remove them from the unit and set them in their jewel cases. If the unit was not ejecting the disk and it was stuck, check to see if the CD was perhaps stuck between the spindle and the arm that holds the CD to the spindle. That happens sometimes on CD players. If that is the case, you should be able to remove the CD anyway but you have to be careful and not be too forceful to any mechanisms involved. I hope that helps.
Oct 25, 2009 | Audio Players & Recorders
Xplod cd player reads Err 99 and wont accept cd
I had the same problem.
i fix it by taking out the cd player and pulling the outer case off. when i looked inside and the (in technical terms) metal bracket that holds the white plastic disc (that i guess holds the cds) inside the cd player was bent down. i am assuming that cds were hitting this when i tried to insert them! i just bent it back up using a knife from the outside. i bent it up until the white disc looked level.
good luck
May 16, 2009 | Sony Car Audio & Video
Broken small round piece that holds dvd onto the platter
reset centrel on round piecein dvd player just push carfully and check round piece is sumuthly turned if ok then play DVD /mp3 cd [ if totaly brokon you replace with new]
Apr 06, 2009 | Coby TF-DVD7100 Portable DVD Player
THE PIECE THAT HOLDS THE DVD IN PLACE COME OFF IS THERE ANYWAY TO
I am assuming you are talking about the piece that freely rotates and comes down on the dvd to hold it down against the motor that actually turns. Yes most tv repair shops can repair that, because I know that I could. That particular part is almost the same in any model dvd or cd player for that matter. How they mount or attached is the only slight difference. But it is definitely fixable. God bless.
Jan 09, 2009 | Durabrand Portable DVD
Stopping partway through a CD.
This is not possible to change as it is the nature of all CD players, unlike DVD players which give you the stop/resume function. Cd players have a similar function called pause, but other than that its alm,ost impossible to fully stop and start off again from where you left off unless you skip to the track and hold the skip button to fast foward/rewind.
Dec 26, 2007 | RCA RP2710 Personal CD Player
Sony CMT-ED1 Shelf System Logo
159 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
