Question about JVC DR-MV1S DVD Recorder/VCR
Hello, I am installing my recorder. I just had
Hello, I am installing my recorder. I just had the cable guy out here hook it up. However, the unit just keeps blinked "Loading" and I cannot open the DVD drive.
  • 11,896 Answers
The firmware may be faulty. Try unpluggin it for 10 minutes, then hit power button, wait 20 seconds, plug back in and try again. If problem persists, it will need new firmware or circuit board
Posted on Sep 23, 2009
  • JVC Master
  • 3,866 Answers
Okay if its new out of the box there is a security latch on this that nees to be disenaged if not you might have a issue here with the ejector motor.
To verify this and if this is out of warranty you can open this unit up if your experienced and check the motor it might be cought on something or there may be a disk jammed inside ASSUMING you had this recoder and its not new. Good luck when in doubt about new or used products seek manufactor advice before serviceing
How do I hook up my Sanyo Model # FWZV475F VCR-DVD recorder to TV
Get one of these HDMI cables that will attach BOTH units..
turn OFF BOTH units before you install HDMI cables.... once you have both units connected... turn the power on and start as usual.. this should hook it up!!
How to Choose the Right HDMI Cable
Sep 19, 2017 | Sanyo Televison & Video
I had a new high def tv installed.the cable company hooked up there box .now i cant record anything on the vhs.
was the VHS recording before the new high definition TV was installed? Or are you trying to say that the cable company has tempered with the settings of the VHS?
Probably, the cable company, has removed the cable for the player. Check the back of the player and let me know if the cable between the player and the TV are intact.
The above needs to be verified for accurate solution.
I look forward to your reply.
Bye for now.
Jan 20, 2011 | Sanyo DVW-5000 DVD Player/VCR
I am trying to record cartoons for my 4 month old onto dvd from cable... I cant quite figure out how to hook it up.
The device unit?U must have DVD/VCR recorder player to record things out of cable tv or other tv signals.Not just a DVD/VCR player.Read ur manual for instruction,u hook up a VCR before right,the same principle.
Dec 07, 2010 | Samsung DVD-VR357
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
Jan 13, 2010 | Philips Magnavox DVD/VCR Dual Player
TV sparking when hooking up cable
Hi, there is a sparking sound probably because whatever your cionnecting it from is still on. So switch of the unit where the cable is coming from, maybe its froma signal booster? and plug it into your tv, also there maybe still current running through your tv so switch off your tv aswell. It is quite common for connectors to spark when the equipment is on because the connector is try to make contact and there is a voltage present. I'm guessing that the TV works fine once the connector is inserted in or hasnt your cable guy gotten that far yet?
As long as its not a large spark and the source which the cable is connected to is not a high voltage source, which I dont see any reason why it should be. Also check the grounding of the cable. Considering you have a cable guy installing the equipment I'm suprised they do not know whats going on.....
Regards
Rob
Nov 26, 2008 | RCA HD50LPW175 50" HDTV
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
JVC DR-MV1S DVD Recorder/VCR Logo
310 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
