Question about Maytag MSD2756G Side by Side Refrigerator
Refrigerator and freezer both are not working. fan in back of unit running but internal fan not running. i also cannot hear the compressor kicking on.
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Sep 23, 2009
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Compressor kicks/clicks out after approx 10 sec run time,fan runs normal,not froze up, freezer barely cools,negative frig, happened overnight to 6 yr old unit
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Refrigerators
Compressor doas not kick on ,when it try,s to-the fan speed drops for aprox. 3 seconds ,and then the fan goes back up to speed but no compressor.
heatman101
Aug 05, 2011 | Refrigerators
My Samsung RS2630SH fridge and freezer are not staying cold. The condenser fan is running, I blew and vacuumed all dust off of the coils. If I unplug it for a few minutes then plug it back in the...
heatman101
Jul 09, 2011 | Refrigerators
Maytag/Mod MSB2354GR SER # JSU18X156A0A compressor kicks on but kicks off again. after 2 or 3 seconds . on again/off again No cooling in either side Cooling fan runs all the time
heatman101
Mar 15, 2011 | Maytag MSB2354G Side by Side Refrigerator
Freezer and Refrigerator are both warm. Fan is
Sounds like the compressor is gone, or the coolant has leaked out. If you can hear the compressor kicking on then the odds are the coolant is out.
Feb 28, 2011 | Maytag MTB1955GRW Top Freezer Refrigerator
The motor works but not getting cold enough,I am not hearing anything in the freezer section like such as the fan
Hi, you say you hear the motor running? Do you mean the compressor motor? You have 3 motors, the compressor, condenser fan motor which both are located in the back and behind a panel with a small condenser coil. And, the evaporator fan motor in the freezer.They all must be running for the unit to operate right. You can check the 2 in the back by removing the panel and checking them both. Clean the front of the coil while you are back there, this will keep the internal pressures down to a cooler temperature. If the fan in the freezer doesn't run at all, this will be your problem. It must be changed. Make sure you have no switch around the perimeter of the freezer door that stops the fan when the door is opened first. Some models have them and most do not.If its not running, unplug the box and do your best to remove it. You can buy one at a appliance parts store, with the model, serial, and name of unit. Check all I have said first and keep me posted. Make sure you turn the control stat down so all will run.
Shastalaker7
Feb 05, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
Fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Side by side whirlpool refrigerator with easy water and ice, not
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
258 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
