Question about Palm Treo 700wx Smartphone
The treo logo appeared on the screen of my 700 WX, and the phone is completely frozen now, I have tried several soft resets, I have not executed a hard reset, as my data is not backed up. Please help....Thank you.
My ipad is frozen
  1. If the iPad is frozen or stuck, hold down both the Sleep/Wake button and the Home button. This will force the iPad to power down.
  2. The iPad screen will display the circle of dashes which indicates it is busy. Once the iPad has finished shutting down completely, the screen will go completely black.
  3. Once the iPad's screen is completely black, hold down the Sleep/Wake button for several seconds. This will allow you to restart the iPad.
  4. When the Apple logo appears in the middle of the screen, you can release the Sleep/Wake button. The iPad will restart shortly after the logo appears.
Aug 31, 2013 | Cell Phones
My treo 700 wx has low signal strength
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 08, 2012 | Palm Treo 700wx Smartphone
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Cant find cd to set up computer and hotsync phone to
Here you can find all information related to your Palm Treo 700 W:
http://kb.palm.com/wps/portal/kb/na/treo/700w/verizon/home/page_en.html
If you want to hotsync your phone you need to download the Microsoft Active Sync software from this site:
ActiveSync Software
for Windows XP icon_activesync.png Download Updater 1.22 (Windows Installer) for Treo 700w/wx for Verizon downloads-item-update.png Update your phone Update Windows Mobile
Device Center for Vista icon_activesync.png Learn more
Hope it helped.
Nov 19, 2009 | Palm Treo 700w Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Its locked up
Is your Palm Centro device locked up and frozen. You might want to try a hard reset. Here’s how.
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the second Palm logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Mar 31, 2009 | Palm Treo 500 Centro
My palm treo 700 wx won't sync
Try uninstalling the Microsoft Activesync. The Palm website offers the newly, innovated Activesync software available for your device. I would recommend reinstalling Microsoft Activesync from this support site.
Mar 27, 2009 | Palm Treo 700wx Smartphone
DROPPED PHONE NOT SURE WHAT I NEED
You can replace the lcd screen and digitizer.
Its about $40 US on ebay. Try searching treo 750wx screen/digitizer/touch screen, etc. Also i tried searching treo 750wx but it didn't work, I suspect the 750 to be the same as the wx, but you might wanna make sure with the seller incase (Ask seller a question link is on the listing, or click their username and go to their profile and click on contact)
Feb 27, 2009 | Palm Cell Phones
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Palm Treo 700wx Smartphone Logo
117 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
