Question about Evenflo Triumph Advance LX - Harbortown Convertible Car Seat
Do I need to replace my eveflo triumph LX after any accident? I had a minor accident today, no damage to my car, my back hurts a bit but thats about all? It felt like Ijust braked really really hard.
  • 164 Answers
Yes, you should replace a car seat after any accident.
Posted on Sep 24, 2009
Will it hurt the engine in anyway to just remove the baffles from my 2013 triumph thunderbird?
Although it won't damage the engine, it may well cause the engine to run poorly (loss of power, run rough etc.). You can change exhaust systems but sometimes you need to re-jet or re-tune the engine
Aug 04, 2015 | 2013 Triumph Thunderbird ABS
My car sounds like a bell!
I would suggest checking to see if you bent the exhaust when it hit the pole. The 1992 camaro has very little room for the exhaust system to run over the rear axle to start with it would not take much to make it hit under the car
Dec 05, 2013 | 1998 Volkswagen Jetta
Ignition
ur wiring harness has damage--inspec it slowly with a clymer repair manual--wires are worn probly from a # of reasons-causin shorts etc--dont du more until u do this--may hurt electronix
Mar 22, 2013 | 1996 Triumph Triumph Thunderbird
Can a minor accident cause damage to the bank 2 intake and damage the control unit on a xenon headlight ?
No, they are just being dealerish. I could believe what they say needs replacing probably does, but why make you return again and again? Rather than fix it right the first time, with proper testing to assure it is right, they would rather have you come back, and start charging you all over again. That sure helps their bottom line. Dealerships are getting a notorious reputation for poor customer service, and desevedly so. Most of them only care about selling new cars, not helping customers with old cars. Go somewhere else, like an independent shop , to get the headlights aimed properly. Probably much cheaper than dealer prices.
Apr 02, 2012 | Cars & Trucks
After minor front end accident damage. Brakes won't fungtion, almost no brakes and pedal bottoms out. Changed master cylinder an bled brakes with no improvement to problem. Engine vacume nine lbs.
was it a new master cylinder or a old one?' under the master cylinder is a load sensing equalising valve its a 136 euros piece of spare part new is this ok or was that damaged in the accident ,iam going to bed had a late night on a breakdown last night and then up early so iam a bit tired to think straight sorry
Aug 25, 2011 | 2001 Daewoo Lanos
Currently own a triumph speed four 06 tornado red was involved in a minor accident. cut up but car nd had to ditch me and the bike in a mounted ditch. bike went upside down and landed in a hedge nearby....
Hi, Whwarrenhugh Triumph's are pretty tough and just because it landed upside down is no reason to pull the top end. Try bleeding the cooling system of air that traveled to places it was not welcomed while the bike was on it's back, then retrieve the generated fault code and go from there.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bleeding the cooling system
How to find fault codes on triumph motorcycle
Engine Fault Codes
Triumph Speed 4 TT600 2000 2006 Factory Service Manual PDF Download... $10 cheap
Hermys Triumph Motorcycle Parts Triumph Speed Four Genuine Motorcycle...
http://mybikemanuals.com/triumph
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 31, 2017 | 2005 Triumph Speed Four
1997 honda civic lx involved in a minor accident, airbags did deploy, now cranks but, won't start....replaced the mains relay but still won't start. Need idea of what may be the problem
If the airbags deployed, I suspect the car took a good
hit. If the car is worth keeping, considering the air bag
situation alone, I would take it to the dealer.
Jan 26, 2011 | 1997 Honda Civic
1994 corolla. minor accident pulled rear plastic
check for burnt fuse and wiring damage at bumber causing short condition!
Jun 22, 2009 | 1994 Toyota Corolla
2003 Cavalier, fuel problem after accident
there is no fuel pump cut off switch on this car, it is possible the fuel pump module was damaged from this accident, u will have to have the fuel pump circuit tested for faults before replacing the pump, don't guess, this is an expensive repair
Mar 09, 2009 | 2003 Chevrolet Cavalier
Evenflo Triumph Advance LX - Harbortown Convertible Car Seat Logo
148 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Dennis Crouse
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
