Question about Sirius STILETTO 100 MP3 Player
The scroll wheel does not respond
All the functions of the reciever work. however, when i try to turn the scroll wheel to change channels/songs in is unresponsive. any ideas would be much appreciated
Go to ebay and look under Stiletto Wheel. A guy in Maine will fix it for $24.95. I overnighted it to him on Monday and got it back on Friday. It works perfectly, well worth it.
Posted on Oct 02, 2009
Testimonial: "thanks a lot...i'll check that out"
Never had an issue until yesterday... When I turn the tv on,it immediately begins scrolling through all the channels and won't stop. It will not respond to the
I will assume you tried to unplug the set and plug it back in.
If you are using a sat or cable box connected to the cable fitting on the set try connection from the AV jacks to one of the video inputs on the set.
If set does it via the rear jacks it is likely the box and not the set.
Mar 15, 2012 | Samsung HL-T6187S Television
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Problem with the wireless mouse
sounds like you need to resync the mouse to the wireless reciever. if this doesn't work than try replacing the batteries.
Feb 28, 2009 | Sakar iConcepts 4D Wireless Wheel Scroll...
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Logitech mbj58
Check the scroll is strucked or not. And then open and see scroll is properly placed.
Feb 23, 2008 | Logitech Wheel Mouse Optical
Ipod Nano 1st generation
your PCB is cracked or there is debris under the wheel try placing a hoover on the jog wheel (DO NOT RUN IT OVER WITH THE SAID HOOVER OBVIOULY USE THE HAND TOOL) LOL
Jan 23, 2008 | Apple iPod nano
Remote problems and now FPA locked
In the worse case:
It is very possible that the remote recieve on the set has gone defective. It is also possible that there is a fault with the processor in the set, and the remote signals are not being responded to.
As for your universal remote, I don't trust them.
Did you try changing the batteries in the remote? Make sure the new ones are actualy in good condition.
Jerry G.
Jan 01, 2008 | RCA 32V420T 32" TV
Satellite receiver not responding
was you satellite tampered with? If so then it could be an eeprom jam!
Sep 02, 2007 | Audio Players & Recorders
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Sirius STILETTO 100 MP3 Player Logo
404 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
