Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have just purchased a sony KDL 40W5500. Prior
I have just purchased a sony KDL 40W5500. Prior to this we had a 32" one which was fine but we wanted a bigger one as room is quite large. The picture is pixelating and fuzzy both on analogue and Sky. When on Blue Ray it is brillient. What can I do have purchased gold cable etc checked wiring & aerial wires. Am at wits end. I even believed it could be TV fault and had it changed but of course it was not.
  • 325 Answers
I Install Sky on a Daily Basis When you start getting pixels on your sky it is normally The sky dish that needs re-alligning as the weather/ window cleaner or something has moved it.
You mentioned Buying GOLD plated. They are a waste of money. The back of your telly is Alley and so is the box so you would see no benefit buying installing a gold plated scart / HDMI lead. there two different metals altogether. curry / comet etc are sale people all they want is your £££
Its a shame you did not live in Newcastle. I could have sorted this out for you.
Little Dish Fitter
Posted on Sep 26, 2009
  • 8457 Answers
SOURCE: Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Posted on Aug 15, 2009
  • 458 Answers
SOURCE: I have just moved house to Reading and previously
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Posted on Nov 15, 2009
  • 148 Answers
SOURCE: My Sony KDL-40W5500 TV won't switch on: standby
NOOOOOO, do not buy a new one. Your problem , if you fixed it my way yourself, would only cost you around$3.00 to $5.00....
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not) , then please rate!
Thank you.
Posted on Feb 02, 2010
SOURCE: problems with sony bravia lcd
We had this trouble with our sony bravia, had to get a repair man in to look at it and the digital tuner within the tv went cost $180.00 to have a new digit tuner put in.
Posted on Jan 17, 2011
eagle338
  • 4889 Answers
SOURCE: I have my Sony flatscreen
From the looks of it the tuner seems to be malfunctioning. You are able to get picture through your DVD recorder because the signal is directly fed to the audio/video proecessing circuits , when you connect via the HDMI, Component or RCA ports at the back of the tv. Since this mode of connection also ensures better quality signal I suggest that you continue using it as this problem can only be resolved by replacing the main A/V board on which the tuner is located. The board costs about 100-125$ and is not very hard to replace. So if you wish to replace it, then let me know and I will give you the detailed instructions along with the link to the part.
P.S: Bad Rating = No further help.
Posted on Aug 15, 2011
Testimonial: "Thanks very much - that's bad news but at least I now know the problem!"
NEED A USER MANUAL FOR A SONY BRAVIA TV MODEL KDL-40W5500 MODEL 9201533AN YOU HELP PLEASE THANK YOU
Sony has the manual for the KDL-40W5500 on the product support page: http://www.sony.co.uk/support/en/product/KDL-40W5500 . Scroll down to the Manuals section and there are two documents immediately shown. There are additional manuals stored on various Sony sites available, if you click on the link for all manuals. The direct link for one version of the manual in English is http://download.sony-europe.com/pub/manuals/swt/Z006/Z006062111.pdf .
I hope this helps.
Sep 11, 2016 | Sony BRAVIA KDL-40W5500 FULL HD...
Sony kdl 40w5500 hdmi not working
Take it to the technician he can only solve the problem.
Jul 01, 2013 | Sony BRAVIA KDL-40W5500 FULL HD...
My remote for my Kdl 40w5500 tv doesn't work properly?the volume,programme,theatre & on/off buttons work but none of the others do????????
Common cause is the liquid substance from old batteries of remote control. Just clean the rubber contacts and printed circuit board inside of your remote control with alcohol and cotton or cloth, let it dry for few minutes, then re assemble your remote control and it's done...
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40W5500 LCD TV (11months old) that does not show a picture when turning on from standby. Sometimes it only gives sound for a shot while then automatically reverts to standby. the...
probably there is a problem on the power supply section of your tv the cause of it is a deffective bulging capacitors.replace all the bulging capacitors from the power supply.
Oct 16, 2010 | Sony Televison & Video
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Apr 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
300 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
