Question about Garmin nuvi 1300 Car GPS Receiver
4th day w/Garmin 1300T and it powered off after 3 hours.
The unit worked perfectly for 3 days and on a trip home after 3 hours it powered off and will not turn back on. It was plugged into power outlet and the red light was on.
Hold on/off button depressed for at least 30 sec--happened to me, and works just fine now.
Posted on Oct 05, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
I have a Garmin Nuvi 1300t, I tried to enter my UK post code which has been valid for 25 years and I get a different street example I type in MK15 8PL select 12 and I get 12 St Stephens Drive MK15 8QB and...
My nuvi 1300t will not find satellite. I did as is says by taking outside away from buildings/trees. Haven't used it in a few months. Updated it. still doesn't find satellite. It says it's at the last location that I used it.
Sep 21, 2010 | Garmin GPS
My garmin 1300T turned itself off and will not restart
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your 1300T is listed as a $99 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin NUVI 1300T which is about 2 months old and has the most recent software, with a full battery charge or plugged into a power source occasionally switches off completely during a trip and will not...
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin 1300T just turns off. After hours or days it comes back on. One time in the middle of 6 hour trip it just shut off. I have the newest software and have replaced the unit 5 times and all of them...
OK i have the answer ,man i had the worst trip EVERY thanks to this charging flaw, the flaw is that the unit can only charge while off, so if your on a trip this will not work i had to drive 3,100 mile there and back i literally broke down and cried i was lost in tenissi with no idea what to do or where to go, i LOVE, LOVE, LOVE this gps but it has a very big flaw in it being that you can only charge when it is turned off
Jan 03, 2010 | Garmin nuvi 1300 Car GPS Receiver
What do I do when my brand new Garmin Nuvi 1300t freezes up?
Do this: Reset the unit with the pin hole button on the bottom. If this does not work, try holding the power switch to the left for 8 seconds.
Dec 30, 2009 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1350 powers down while travelling i have to hold power button on to power back on
ALL GPS require charging via the AC charger or USB supplied, If you have not done this then the battery will lose power quickly when connected to 12v car outlet. This source is a maintenance charge, not the main charger. Therefore it will deplete and try to shut down, despite being connected. Holding the power button on to force it is a dangerous driving practice and will eventually damage the unit( not so bad as getting you and any passengers damaged by this practice)
Charge your unit fully before you use it, if that is daily then disconnect it and put it on the AC or USB to raise the charging level to full so it's ready to go for the next day.
If it fails to charge fully, then your actions have damaged the battery and it will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1300t
is the outlet in the truck working, that is to say does it have power?
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
290 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
