MY PC-2LX COPIER copy board goes only half way than cuts out .I get E-2 flashing light. When it worked before moving it did not copy any thing.
    President:
  • 3,085 Answers
Look in the rear at the bottom of the screen and make sure the gear that drives the screen is meshing with the drive gear.
Posted on Sep 24, 2009
COPIER FLASHING F5
Hallow there. if you press copy key it should show 02 on the display meaning a problem with copy lamp. Please check the optical unit area for the following;
  • Check that the copy lamp board is well connected to the main board .
  • Check that copy lamp is lighting.
  • Check the document glass is well locked with the white part secured with screws.
If all the above is okay, then switch it on and work.
Jan 07, 2011 | Sharp AL 1631 Copier
Error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jul 15, 2010 | Sharp AL 1631 Copier
Copier flashing error message
You did not provide the make and model of copier but this code is common among Sharp AL series copiers which are sold under various models. I have pasted my tip on the solution for this code so it should work for you.
Apr 13, 2010 | Toshiba e-Studio162D Copier
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
The start key does not stop its cycle
Control panel definitely needs replacement. Based on the age of the unit and the cost (at least $350) of the repair, I would recomend replacement.
Nov 10, 2008 | Canon NP 7130 Black and White Copier
My copier stop at half way.laser light goes to the right & dont turn back.
You are not looking at th laser. If you are you will go blind. You are most likly looking at the scanning lamp. You did not say what make or kind of copier. Also, do you get a error code? Also, do you get a small part of the copy and the rest is black? If you get part of a copy and the rest is black, you have a analog copier and most likely you have a cracked or a short caued by a crack in the scanning lamp power cable.
Oct 17, 2008 | Office Equipment & Supplies
Xerox xc1045 copier machine
If it starts to make a copy and the light comes on then stops in the middle there is a problem w/the connection.
check the cable that turns on the light it may have a cut and is not making contact in a particular spot. If not then it may be the board that controls the lamp.
Oct 17, 2008 | Xerox 5665 Copier
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
22 people viewed this question
jasbo
jasbo
