Question about E-Machines T2240 PC Desktop
Hard Drive light spazzes and fan works but nothing else!!
It has recently come to my attention that someone was screwing around with the computer( pushing the on/off button repeatedly while the power was down) and now when i try to turn it on, the hard drive light blinks rapidly and gets faster, and the fan works but nothing else. It is possible that this has short circuited?
Thankyou for you help
  • Tom Sutch Oct 16, 2008
    I have the exact same problem with the fan running slow on the power supply. The cpu fan seems to be running about normal. The power button light is flashing green and the hard drive LED is flashing quickly with a yellow light. I don't see any blown capacitors. Power button does nothing when pushed or held down. The fans start as soon as the pc is plugged in. My father had a different model emachines and the power supply went bad and fried the MOBO. A little different symptoms on this one but I believe it is the same result. Bad MOBO.
  • Stephen McGloughlin
    Stephen McGloughlin Dec 27, 2008
    I have the same problem with my T2865; CPU fan and LEDs on but no beeps video or booting. Power switch ineffective. However, mine now has a brand new motherboard and AMD CPU and the problem persists. Still trying to figure it out, but I'm suspecting the RAM at this point (not much left to swap out). My video card is an ATI AGP (new board doesn't have on-board video) so I'm not sure if that's why I'm not seeing the low level video boot up displays. PSU has also been replaced as that was my initial suspect/theory. Any suggestions for further diagnosis?
    Genius:
  • 1,601 Answers
Sounds like the power button is broken or power supply is going.
Posted on Dec 15, 2007
I'm working on a computer with the exact same issue. The fans come on, but they are all spinning rather slowly. The motherboard has bloated capacitors on it which leads me to believe that it is a motherboard failure. I tried a different power supply but to no avail. I'm out on the 'net looking for a new board since I'm a tech and can replace components like this. If you're not a tech, you're probably best off just buying a new Emachine.
Posted on Dec 28, 2007
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
Power supply unit starts (fan running) but computer does not....
Try swapping out the ram 1 at a time, making sure there is one memory piece there while testing. If no! check hard drive for activity.
Mar 14, 2012 | HP Pavilion a1102n PC Desktop
I have asus motherboard product number m4n68t-m. The computer randomly goes black with all my lights running and my fans still working, but nothing else. I've recently put a new hard drive in to see if...
its hard to tell what your computer has.. but i think it might be the monitor and not the computer.. i had a similar problem and it apeared the monitor was broken aswell check your videocard adaptor and the cable witch connects the pc and monitor
Sep 06, 2011 | ASUS Computers & Internet
My hard drive will not turn on, plugs are all in green light flashes in the back, but nothing else, no fan, no light on the top of hd nothing but a flshing green light in the rear of the casing
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 23, 2011 | HP Computers & Internet
My samsung R519 will not turn on. The battery is fine. However, when putting it on the on light goes on but the others dont. You can feel the fan begin but nothing? Any ideas?
If you feel that the fan does not move the all, that is the main cause of your problem. To reseat the fan, kindly turn off your laptop, remove cables & battery, press and hold power button for 8 secs, remove the screws at the back of the battery, remove the hard drive, remove the optical drive, and then reseat the fan. Then insert back the optical drive, hard drive, screws, cables and battery then turn on the laptop. IF it did not work, you need to call Samsung to replace your fan.
Aug 22, 2010 | Computers & Internet
Hi, my external hard drive recently cannot be detected by my laptop. i ran a virus scan and found the usbdur virus, which i have already deleted. however, after so many tries, the external hard drive still...
Hi there
I dont know if this will work for you but looking on the web I came accross someone who had a similar problem they fixed it as follows.
They installed Tweak UI and then
She was able to get the drive recognized using "Tweak UI", clicking on My Computer, Drives,and check marking Drive F. It did the trick.
Hope this helps software link for you
http://www.annoyances.org/exec/show/tweakui
Mar 17, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Computer may or may not start up. When it does, it may or may ..
Go with a known good working hard drive, its the easiest thing to replace and instead of reimaging it, install windows from scratch and then load the drivers for whatever it doesnt find and then see how it runs, if the lockups stop happeneing then load the apps that you want and everything should be okay.
Jun 26, 2009 | HP Computers & Internet
Nothing happens
Depending on how big the knock was it could have been severe enough to damage your hard drive.  The boot up of the machine hence the fan is caused by the CPU heating and the fan cooling it however when the bios and CPU ask the hard drive to boot up it cannot thus that is the failure of your startingup. It may need the attention of serviceman to repair it and even he may suggest a replacement of the hard drive.
Oct 22, 2007 | Acer TravelMate 290 Notebook
E-Machines T2240 PC Desktop Logo
319 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
