Question about Texas Instruments TI-83 Plus Calculator
How to convert from deciaml to fraction - Texas Instruments TI-83 Plus Calculator
  • Texas Instru... Master
  • 8,046 Answers
Press [MATH][1:->Frac] enter.
0.76965 [MATH][1:->Frac] [ENTER] gives you the result as a fraction.
Hope it helps.
Posted on Sep 23, 2009
How do I convert decimals to fractions on the TI Math Explorer (No numbers associated with it - i.e. TI - 15)?
The way it works is as follow. If a result is displayed as a fraction you can convert it to its decimal representation. If you do nothing after the conversion, you can revert the decimal representation to the fraction.
Apr 29, 2014 | Texas Instruments Office Equipment &...
Multiplying mixed fractions
Convert each mixed number (what you call mixed fraction) to an improper fraction, then multiply the two numerators and multiply the two denominators. Reduce the resulting fraction to its simplest form
Example
(2 1/3)*(1 5/7)=?
Convert 2 1/3 to an improper fraction 2 1/3=2+ 1/3 = 6/3+1/3=7/3
Convert 1 5/7 to an improper fraction 1 5/7=1+ 5/7 =7/7 +5/7=12/7
(2 1/3)*(1 5/7)= (7/3)*(12/7)= (7*12)/(3*7)
The 7's in the numerator and denominator cancel one another leaving
12/3=4
(2 1/3)*(1 5/7)=4
Not all products of mixed numbers will give a simple result as this one. More likely they will not.
Dec 12, 2013 | Computers & Internet
F-D key in Polynomial
The F-D key converts a displayed result from fraction to decimal and vice-versa.
If in the polynomial expression a numerical coefficient is a fraction just enter it as a fraction, possibly enclosed in parentheses. If it is a decimal number just enter it as a decimal number. Converting it to a fraction is not going to generate any more precision in the result. You lose precision when you go from fraction to decimal, but you do not make a number more precise by converting it from a decimal representation to a fraction.
Nov 16, 2013 | Casio FX9750GII Graphic Calculator
Fraction to degrees
There must be an error in the question. Could it be fraction to decimal?
The MATH menu has two options 1:>Frac, 2:>Dec.
The first entered on the command line after a fraction keeps the result in (reduced) fraction form. On a displayed result, it converts a decimal into a fraction.
The second 2:>DEC converts a fraction into a decimal number.
The latest OS (2.53MP and following) has a better handling for fractions.
Feb 27, 2012 | Texas Instruments TI-84 Plus Calculator
My TI 84 won't convert my imaginary numbers to fractions. I typed in 1/(1+i) and it won't convert the answer to fraction form. It keeps saying Error Data Type
The TI-84 works with real fractions. It will not convert complex numbers to fractions.
You can convert the real and imaginary components to fractions separately. For your example, 1/(1+i) is .5-.5i. Converting .5 and -.5 to fractions, you get 1/2 + (1/2)i.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
Dec 29, 2010 | Texas Instruments TI-30 XIIS Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
How to convert fractions to decimals
To convert fractions to decimals, and decimals to fractions use the [a b/c] key. If the total number of symbols (num, denom, fraction bar) to display a fraction exceeds 10, the fraction is automatically converted to decimal format.
Jul 19, 2010 | Casio FX-300MS Calculator
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
