Question about Sony Playstation 3 (PS3) Console
My consul does give me hd resolution. It says that it is on . How can I be sure I have it set up right?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
If you have just an HDMI cable plugged in and your seeing video on your tv , its setup right. you cant see HD on the analog plugin and vise versa and the ps3 will use the maximum output of video based off the what the game supports and what your tv can support. if you want to test it most HD tv's will tell you the resolution its using by hitting the display button on the tv remote or just turning the tv off then on ussually shows the display
Posted on Sep 24, 2009
Well everytime we hook up the HDMI for the playstation 3 to the tv it says invalid format how do i fix this
You must make sure your playstation and your TV set are both set for the same video format (1080p, 1080i, 720p, etc.).
You can either go through all your HDTV formats until it synchs up (give each a good 20 seconds or so before moving on), or you can open the display menu for your PS/3 using a different video connection to your set (i.e. composite), setting both to match, then switching them to HDMI.
Feb 15, 2011 | Televison & Video
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
Hi.. I have recently bought a dell 15R inspirion.. Hardware - Intel i5 -460M 2.53GHz (Turbo boost upto 2.8Ghz) 4GB DDR3 500GB HDD 1GB ATI -HD 550v Win 7 Home Basic Problem - The display quality...
First of all make sure you are not in the "Safe mode". To adjust your display setting to a better resolution, you can right click on the background, and a small screen will apear, then go down to personalization and click it. It will pop up a window and on the left side, there should be a "display" and you want to click this and switch to the display screen, and still on the left panel there is this " adjust resolution" click this and adjust your resolution to a higher resolution. Saying that, if your computer running kinda low, then it's probraly all that dell preinstalled programs. You might want to also check your system spec in the windows system information to see if you are getting the full specs. If you are, then it's gotta be the preinstalled programs. I have a i5 450m gateway laptop 4gb of ram, and brand new it lagged more then my i3 dell studio which wasn't preinstalled with bunch of crapwares.
Jan 18, 2011 | Dell Inspiron 15R~15.6" HD LED Display...
I have macbook pro and a 30" apple hd cinema display the best resolution I can get on the display is 1280x800 where are the higher resolutions?
Your computer will always give you all available options for resolution. If there is no higher resolution available in the settings screen, there is no higer resolution available for you. This is linked to your graphical processing unit inside your PC. This cannot be changed that easily
Oct 27, 2010 | Apple Cinema HD 30" LCD Monitor
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
How do i set my x193w lcd monitor to hd?
install the CD that came with the monitor else right click on monitor screen in windows and adjust on properties menu
Nov 22, 2009 | Acer X193W LCD Monitor
Resolution problem
install your graphics card driver first
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Dec 22, 2008 | Sylvania LC320SL8 Television
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
