Question about LG 42LC2D 42 in. LCD HDTV
Our LG tv keeps turning itself off and it usually comes on eventually but this time it wont come on at all.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
What most likely hapend was a componet was heating up and failing after it got hot, After a while the component finally failed and now will not turn on. Without a diagram this would be difficult to fix yourself. I would suggest getting a quote from a repair shop. Sorry for the news, good luck, I hope this helps.
Posted on Sep 23, 2009
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
My 32LG350 wont turn on. I just pluged it for the first time i bought it like a month ago. it was working but suddenly it turned off by itself and wont turn on either by pushing the TV on/off boton neither...
Try unplugging the the TV from the power outlet for 30 seconds to a minute and plug back in again. Try to turn on again. Some TV's have to be in a "ready mode" to operate by remote - so besure it is in that mode - or use the power button on the TV.
Apr 01, 2011 | LG 32LD350 32 in. LCD TV
LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Aug 27, 2009 | LG 37 in. Flat Panel LCD HDTV
Lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 20, 2009 | LG 32LC7DC 32 in. LCD HDTV
I have a 50inch lg ready tv but wont switch on red power light there but when i switch on light goes away for 15 mins but tv wont come on
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
Jul 19, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
FD Triniton Wega XBR KV-30XBR910 TV WON'T TURN ON, LIGHT FLASHES 6 TIMES RIGHT NOW, SOMETIMES IF I KEEP TRYING USUALLY SEVERAL WEEKS AFTER TURNING OFF IT WILL TURN ON, BUT WILL EVENTUALLY TURN ITSELF OFF...
If you are handy with TV repair then replace IC6501 and IC8002 on D board of TV or ask local TV repair shop to replace it. Both ICs have same number MCZ3001D
Thanks.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
LG 42LC2D 42 in. LCD HDTV Logo
513 people viewed this question
Computer Repairing
Computer Repairing
