Question about Uniden 5.8GHz Dual Cordless Phone
I have the Uniden DX700 expandable set. My phones
I have the Uniden DX700 expandable set. My phones all of a sudden stopped ringing when there is an incoming call. The caller ID won't even show up that there was an incoming call. I can make outgoing calls. I plugged in a non-cordless phone, which does ring, and if that phone rings I can hit talk on my Uniden phone and it will pick up. Also if I am on the Uniden phone, my call waiting and call waiting ID do work. I have tried multiple times de-registering and re-registering all of the handsets but nothing works. The phones just won't ring or even recognize there is an incoming call.
  • 4 Answers
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
have the same problem with a Panasonic KX-TG9344T phone bought from USA used in india. is it a local generated problem?
Posted on Jun 28, 2008
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
  • 84 Answers
SOURCE: cordless phones expandable to 4 with T-coil
Any Uniden DECT 6.0 series phone will have T coil and can expand to either 4 or 5 handsets.
Posted on Feb 27, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How do I set the number of rings? I would like a longeer time to get to the phone - thus, more rings.
You didn't include the model number of your Uniden phone so I've given you the link for Uniden's site where you can download Uniden manuals. Send a comment with your phone model number if you need additional help.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Feb 27, 2011 | Uniden 2.4 GHz Expandable Phone System...
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
My uniden phone rings and goes to answering machine in 2 rings
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
HOW TO CHANGE THE NUMBER OF RINGS BEFORE THE MACHINE ANSWERS?
This is for a 5.8 GHz uniden. Hit "menu/clock" then use volume up and down key to select number of rings and then below "menu/clock" hit "set". That should it.
Apr 18, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
My Uniden Digital 5.8gh cordless phone does not ring
Since you didn't specify the model of your Uniden 5.8GHz phone, I can only suggest you select it from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Dec 26, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden tru9460 ring tone
Cycle through the menu until you see ringer settings, then follow the prompts.
Dec 19, 2017 | Uniden 2.4GHz Expandable Cordless Phone...
Base Shuts Off
You can go to Uniden.com to see the manual for these phones.
Jul 09, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden 5.8GHz Dual Cordless Phone Logo
35 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
