Question about HP OfficeJet 7110 All-In-One Thermal Printer
HP Officejet 7110 - Scanner failure message
On power up I get a scanner failure message and instruction to power off and back on. This keeps reoccuring.
Beni S-P
  • 1006 Answers
SOURCE: Help with HP d135 all in one printer,scanner, fax
HP Error Codes
These error codes apply to many HP & Panafax machines
001 recording paper jam
002 recording paper jam
010 no recording paper
014 print cartridge is not attached
015 out of ink
017 wrong paper size
030 document misfeed
031 document jammed or exceeds maximum length (2 meters)
039 during dialing, STOP was pressed
041 out of toner
045 no toner cartridge
060 a cover or door is open
061 a cover or door is open
063 jam access cover is open
316 clean the ink station overflow tray and encoder strip on inkjet models
400 during initial handshake, RX station did not respond; comm error
403 no polling capability at remote side
404 during initial handshake a comm error occurred
405 during initial handshake a comm error occurred
406 password mismatch
407 no confirmation from the RX station for the previous page sent
408 remote side confirmation of previous page is illegible
409 remote side confirmation of previous page is illegible
411 polling password does not match
412 no data from the transmitting side
414 polling password does not match
415 polling transmission error
416 received data has too many errors
417 received data has too many errors
418 received data has too many errors
419 received data has too many errors
420 machine enters RX mode but receives no command from TX side (not a fax calling)
422 interface is not compatible
427 interface is not compatible
430 comm error occurred while receiving
434 comm error occurred while receiving
436 received data has too many errors
456 memory overflow on confidential document or relay request
490 received data has too many errors
492 comm error occurred while receiving
493 comm error occurred while receiving
494 comm error occurred while receiving
495 telephone line disconnected
540 comm error occurred while transmitting
541 comm error occurred while transmitting
542 comm error occurred while transmitting
543 comm error occurred while transmitting
544 comm error occurred while transmitting
550 telephone line disconnected
552 comm error occurred while receiving
553 comm error occurred while receiving
554 comm error occurred while receiving
555 comm error occurred while receiving
580 sub-address TX to a unit without sub-address function
581 sub-address TX to a unit without sub-address function
601 ADF misfeed
623 no document was on the ADF
630 redial unsuccessful (busy line or no response)
634 redial unsuccessful (busy line or no response)
631 during dailing, STOP was pressed
638 power failure occurred during the communication
640 telephone off hook after comm is completed
870 memory overflow while storing TX documents
879 memory overflow while storing RX documents
975 DRAM parity error (document info in memory is lost, very common, also clean encoder strip)
HP 200/300 and similar models GPM (printer assembly) failure: When the inkjet carriage is homed on the right side of the unit, the spring pointing toward the rear of the unit passes under 2 "actuators" that appear to be identical (mounted vertically, L-shaped). Under heavy usage, the lower end of these actuators is worn away. To remove the actuators for inspection, carefully rotate the paper pickup feed wheels while pulling upward on the L-shaped actuator (compare the 2 actuators, or compare them with actuators from a comparable machine that is in working order).
Many HP and Panasonic inkjet models are comparable and parts can be ordered from Matsushita.
If there is an encoder strip (scale) in inkjet models, clean it to correct a wide variety of problems (HP 900, OfficeJet, Panafax UF321). The encoder strip resembles a narrow piece of cellophane tape, and can be found behind and above the silver bar on which the printhead rides. Easily broken ... use caution when cleaning with a cotton swab dampened with water or rubbing alcohol. When dirty from overspray, the strip can cause all types of problems.
In the Maintenance Mode of HP and Panasonic machines there is a wealth of information. For example, print out the function parameter list to get the lifetime TX/RX/PRINT counts (usually option 3 instead of option 6 in the following example for the HP 200).
HP 200 ram clear
Press # dial dial dial dial * 6 start
Exit the maintenance mode by pressing 9 9 9 start
[Note: to print function parameter list substitute 3 for 6 in the line above]
[Note: to execute a self-test substitute 0 for 6]
[Note: to set parameters 000-999, substitute 1 for 6]
[Note: to test modem/tones, substitute 4, 5, or 7 for 6]
[The TX/RX/COPY counter is item 061 on function parameter list]
HP 300/310 ram clear
Press function 7 dial dial dial dial * 6 start
HP 700 ram clear
Press and hold stop and menu for a few seconds
Press 7 0 0
Press up-arrow key 4 times until display reads 09 memory clear
Press start
Bad line card: replace 2 transistors, 1 diode, and 1 chip. Transistors BS170 (NTE490) @ Q1; 2N3906 @Q3. Diode 1N4148 ar CR2 (next to 2N3906). Chip 74LS14 (74HC14) at U5 (near BS170).
HP 900 ram clear (same as Panasonic UF-321/322)
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
HP 900 disassembly tips (proceed with caution and at your own risk). To remove the operation panel cover: face the rear of the unit, place your thumbs in the outside edges of the document feed path, lift up on the thin edge of the cover while pulling the cover toward you. This should release "snaps" located at the outer edges of the document feed path. Facing the front of the machine, lift the cover up and toward you, then disconnect a cable attached to a board on the rear of the operation panel. To access the document feed mechanism, remove a white plastic retainer in the upper right hand corner of the ADF cover, disconnect the ground strap on the right side of the cover, and slide the cover slightly to the right until it is unhinged. The cover housing the scanner glass can be lifted off after removing several screws, popping two "snaps" at the rear corners, and then carefully popping two more snaps at the front corners of the cover. At this point you would be able to clean one scanner mirror and the ADF sensors & rollers. If you need to remove the line card, you'll have to remove the remaining covers, one screw located at the front of the power supply, four screws that hold the printer assembly in place, one screw at the right rear corner of the scanner assembly, pop two snaps at the front corners of the scanner assembly (remove a long white plastic retainer at the left front corner of the scanner assembly). After gently lifting the scanner assembly upward, the printer assembly can be removed to reveal the line card. During reassembly, be sure to check the positioning of the print paper detect sensor (the spring comes off the sensor and you get an out-of-paper error). Another observation we've made is that on some (but not all) HP 900's, there is a metal retaining clip on the left end of the paper pickup roller's shaft. Apparently the plastic lever (retainer or lock) on the left end of the axle doesn't always hold the mechanism in place in the event of a multi-feed that jams the machine, and at some point in production of the machines a metal clip was added to hold the plastil retainer firmly in place.
HP 900 set number of rings to answer (default is 2)
Press menu 7 dial dial dial dial * 1 start
Press 4 5 start clear
Enter the number of rings desired then press start stop stop
HP Office Jet / LX
For a full ram clear, press and hold * and 1 while turning the power on.
Hold the keys down for a few seconds after the display reads self test please wait then release the keys
For a partial ram clear, press * and 4 while turning the power on.
For the Diagnostics Mode hold * and 7 while turning the power on. Afterwards, new menu items will be found on the display including diagnostics. Turn the unit off afterwards to dump the diagnostic menu selection.
The original Office Jet/LX will print a scanner calibration chart/instructions.
If the modem fails, remove it. Reinstall and test.
Clear Paper Jam: Remove RX tray, press load/eject and paper should load part way; press load/eject a second time and the page should be ejected. If the page ejects ok, then it's not necessarily a mechanical problem, in which case you should clean the encoder strip and sensor. If the page does not load properly, it is probably a mechanical failure. Laserjet paper is slick on one side and may not load properly. Recycled cartridges spray excess ink on the encoder strip
Posted on Nov 05, 2007
SOURCE: Scanner Failure
clean the optical of the scaner
Posted on Nov 30, 2007
SOURCE: scanner failure hp 6110 - Noise and stuck head
Thanks again to Silly Girl. I thought my scanner/printer was dead. It was making some pretty bad noises. I just cleaned both sides of the glass, and it's as good as new.
Posted on Dec 14, 2007
Riztech
  • 731 Answers
SOURCE: HP officejet D135 scanner and copyer
Hi..
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Posted on Feb 11, 2008
SOURCE: Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Aug 19, 2008
Need to set up scanner on officejet 7110.
Connect the printer to the system and power on the printer. Start the system let it boot completely, put the CD that came with the Printer and install the drivers . From the same CD, run the setup to install the scanner software for the printer. Read cafefully the instruction on each installation wizard window that opens and follow the instructions.
However, if you are using windows 7 Operating system, just install the printer driver, go to start, All Program, Windows Scan and Fax. Lunch this and with it you can scan your document
Jan 26, 2010 | HP OfficeJet 7110 All-In-One Thermal...
HP OfficeJet 7110xi
finally you can try a reset on the macj\hine using the # and the number 6 buttons(holding them down and then plugging in the power cord at the back of the machine).If it still gives the same error..try the same with the # and 9...same problem comes up....service the printer
Jun 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
SCanner failure, turn off and turn back on power
Check on the back of the scanner portion that the cable is plugged in to the bottom portion of the printer in the back.
Mar 18, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Cannot scan
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Jan 21, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Scanner failure messege.
I put new bulbs my printer for the same error message, 2 bulbs with freight cost me $49.00. Now instead of error message after 10 or so minutes, it almost immediate. The tech folks in California says 95% of the time the bulbs fix this issue, but when it does not, it is the "board" at a cost of about $90.00. HP 7110 must have this issue and junk is my opinion at this time. Let me know how you come out.
Jan 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Scanner failure error keeping always
HOLD # & 9 WHILE PLUGGING IN PRINTER TO DO FULL RESET
Dec 11, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
275 people viewed this question
Seeker5211
Seeker5211
