Question about RCA 32V550T 32" TV
RCA 32V550T 32" TV Possessed
I turn on the TV and it will work just fine for about 15-20 mins.  Then I lose the picture, but it still has audio.  Then after about another 15-20 mins I lose the audio as well.  Any suggestions?  This TV is less than a year and a half old.
I am having the same problem with my RCA 32V550T. This has been the worst purchase I have ever made - it was an expensive TV at the time that I got it and it only worked for a few months. It may or may not come on. It may or may not have sound. It rarely works but If per chance it does come on it will work maybe from 15 mins to 2 hrs. depending on it's mood - yes I think it is possessed. It turns on and off at will. I keep it unplugged most of the time because I worry it may be a fire hazard. I have had it repaired but the problem persists. It's a useless but expensive heap of junk taking up space in my living room. I had a great RCA VCR that I bought many years ago but contemporary RCA products are not the quality they used to be - be smart and stay away from them.
Posted on Dec 31, 2007
Sound on my tv has stopped working while the video works fine
Check its speaker. If it is found OK, check and replace damaged component/s at its audio output section circuit.
Mar 29, 2013 | RCA 32V550T 32" TV
RCA 32V550T Posessed
This tv is know to have circuits burn out
If you still have the warranty, use it
Otherwise a repair will cost about $150
580-634-0151 support number for rca
If you need anything else, please ask, thank you and I hope you fix your problem
Mar 27, 2008 | RCA 32V550T 32" TV
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Tv rca 32 v 550t bloqueado
alguien save como desbloquear el control de padres de un tv rca 32v550t
Oct 12, 2010 | RCA 32V550T 32" TV
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
Losing picture on tv!
The ITC008 chassis is commonly riddled with poor solder connections. Good soldering station, patience and some good light and magnification and you might be able to fix it... Or you could spend a few dollars and run it into the shop and have a tech do it! It's not an expensive repair.
Bill
Apr 10, 2008 | RCA 32V550T 32" TV
Your high voltage transformer is likely to be ready to go completely out. Thats the way these do. I have replaced many.
Jan 01, 2008 | RCA 32V550T 32" TV
Still posessed!
These tv does have loose of audio problems im concern about looseing picture . Try unplugging tv for 5 minutes it will reset tv very common fix for audio. Tv that are less then a year old are sometimes covered under new warr call manufacture on that.
There is a microprocessor on these that lockup and when you unplug it. it resets it.
I have a tv shop and have helped customers get exchanges under a year especially if you complain
good luck i hpe i helped Thanks DOCTOR VIDEO
Dec 31, 2007 | RCA 32V550T 32" TV
RCA 32V550T 32" TV Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
