Question about Weather King 10AJA2501AH Air Conditioner
WIRING ORDER FOR CIRCUIT BREAKER (4 POST) ON HANDLER UNIT OR PIC
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
How do I find the fuse for central air type is a heil
There's a small 3 amp fuse in the air handler (indoor) that protects the control transformer (there should also be internal circuit breakers and a disconnect outside). The condensing unit (outdoor) is protected by an outside disconnect and circuit breaker.Be sure to shut the power before messing around in the air handler.
Aug 21, 2013 | Heating & Cooling
I just bought a used Carrier FV4BNB006 Air Handler without elec heat (just the air handler itself) . I pulled down the Installation instructions, but dang if I can find the right circuit breaker size to...
Hi, when you get the unit, it will tell you the Min. and max amps on the units data plate.They normally run in the 30 to 60 amp range depending on the tonnage of the air handler. What I would do, is run your lines now, and pick up a 60 amp disconnect box. You can use what ever size fuses in the box that the data plate says. Very easy to find out. Good Luck,
Shastalaker7
A/C, & Heating Contractor
Apr 01, 2011 | Heating & Cooling
Type of circuit breaker for a rudd handler the one attached to the handler
These are special breakers you amy ahve to contact Ruud. Go online for ac parts you will need your model number. If you have a disconnect within 6 ft of unit you can install a terminal block in place of the breaker. Rus
Aug 19, 2009 | Heating & Cooling
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
York Air Handler trips main circuit breaker
almost has to be the electric heat strip coils. they usually come on in stages. when the damaged strip comes on it kicks breaker. turn off all power, check with a meter , gently remove strips and inspect for broken or shorted coils. usually best to buy a new heat strip module. they are usually held in place as a module with 4 screws and a snap together wire connector .good luck. i have had some success if the wires are broken and not to brittle by bending a minute loop in the end of each wire and reconnect with the tiniest screw and washer and nut you can find, i'm talking real tiny. about the size of a bb if you can find em , or you can remove the damaged strip wire entirely to get some heat from remaining.
Nov 23, 2008 | Heating & Cooling
Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Nov 19, 2008 | Gb Electrical 1 30 Amp Ground Fault...
Weather King 10AJA2501AH Air Conditioner Logo
20 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
