Question about Microtek SCANMAKER 4850 Flatbed Scanner
Scanner link failure
What does scanner link failure mean?
0 characters
1 Points
How can I stop my Zerox Documate 515 scanner from trying to update one touch links every 10-seconds?
explore one touch setting or uninstall any other programs related to scan process mean that (use only one touch with scanner driver)
May 13, 2014 | Xerox DocuMate 515 Scanner
We get a pop-up that says tyhe scanner cannot communicate with the computer. We had just used the scanner a week ago and all was fine. Robert Schneider
First reboot your computer, then check you connection with from the scanner to the computer. By this I mean pulling it out of the scanner if its not permanently mounted on the scanner. Then pull out the computer side and push it in and try to scan. If this doesn't work then if you have another USB cable swap it out with the one on your scanner and try and scan again. The only communication link with your scanner is that cable.
I hope this helps you out.
Apr 10, 2011 | Epson Scanners
After installing the scanner I get a message that says "failure in initialization of scanner. Scanner is ofline or scanner power is off." I have checked all of the cables and the scanner is...
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
Mar 31, 2011 | Fujitsu fi-5120C
Failure in initialization of Scanner. Scanner is offline or , scanner is turned off.
First check if the scanner is working in 'offline' mode by 'counting' a few pages.
Connect to the comp, if SCSI is the interface, you need to start the scanner first, if USB you can connect the scanner even after comp powering on. If the scanner is not recognised, reinstall driver software and scanning software.
S. Mohan, Chennai, India
Dec 21, 2010 | Canon DR-9080C Path-Through Scanner
here you will find the driver for windows until vista ...I mean including XP..just put the code in that case and download it ..
Feb 14, 2010 | Scanners
This scanner requires a "Parallel or Centronics" cable and if you have a newer computer, you may only have USB connections. A "USB to CENTRONICS" cable may do the trick, but I'm not sure. Check on the web for one.
Jun 27, 2009 | Umax Astra 1220P Flatbed Scanner
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Black output
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Sep 02, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
HP Scanjet 4600 problem
that means your scanner has a problem internally. bring it to the nearest service center or buy a new one coz its much practical than paying a service fee more than the cost of a new one.
Jan 14, 2007 | HP ScanJet 4600 (refurbished) Flatbed...
Microtek SCANMAKER 4850 Flatbed Scanner Logo
Top Microtek Scanners Experts
Mohan Sriraman
Mohan Sriraman
Are you a Microtek Scanner Expert? Answer questions, earn points and help others
