Revving noise in central air unit
Hi, my central air is cooling well, however it is now making an on and off revving noise that causes it to vibrate. It never did this before. Is th.is a motor issue? What do you think is causing this? It's an old unit that I am trying to keep alive
    President:
  • 1,922 Answers
Are you sure the revving sound isnt a loose grill around the condenser or something setting up an on-off revvind sound-vibration by the speed of the unit,go out to unit and push and prod on exterior of unit and look down inside to see if anything could be loose
Posted on Sep 23, 2009
2002 chevy trailblazer engine revving noise
the revving sound could be coming from the radiator fan clutch with the engine OFF try turning fan should have slight resistance and smooth
Apr 19, 2014 | Cars & Trucks
My tumble dryer is making a noise when on and drum is not turning
Either
-the drive belt has slipped off or snapped (revving motor noise)
-the belt tension spring has broken (revving motor noise)
-the motor start capacitor has failed (heavy hum noise)
Nov 25, 2013 | Dryers
Over revving
Check for a vacuum leak. This can cause a higher than normal idle. It can also cause a surge since the idle air control tries to adjust the amount of air required to idle.
Oct 26, 2013 | Volkswagen Cars & Trucks
What kind if any noise will the transaxle make if bad.
TURN THE WHEEL ALL THE WAY TO THE LEFT, DRIVE THE CAR YOU WILL HEAR A CRACKING NOISE IF THE CV JOINT IS BAD.
DO THE SAME WITH RIGHT SIDE.IF YOU HEAR ANY NOISE CV JOINT IS BAD.
May 07, 2012 | 2000 Oldsmobile Alero
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
My engine is revving up and down on it's own, then will shut off.
Hi.
Check the EGR valve. A defective EGR system is one of the most common reasons for the problem you are describing.
If EGR is OK, check the air intake and air intake sensors. Check also the vacuum system for leaks. A vacuum leak will aspire extra air into the mixture and can cause engine revving up and down.
Regards.
Ginko.
Mar 18, 2011 | 2007 Dodge Ram Truck
I have a 2001 Pontiac Grand Am SE. In the last week my car has been revving when i start it. I have been turning the car off when i notice it revving and usually after three tries it stops revving. Now im...
It sounds like the engine has a bad vacuum leak, they are very problematic for a leaking intake gasket. This usually would be accompanied with coolant loss, but not always. Other causes are loose air plentum snorkel (if air filter recently replaced) or a leaking vacuum hose. It could also be a sign of a computer problem starting. It would be best to have a technician or parts retailer scan it for you to narrow the problem down. The clunk noise maybe unrelated or possibly engine noise(like an intake issue), check the oil and coolant levels first.
Jan 25, 2011 | 2001 Pontiac Grand Am SE
Vax mach 5 burning smell and revving loud
The revving/burning is because the belt is burning off and the power head motor is running without load...
Flip the carpet power head upside down on the rug and look for visible screws and screwdriver release slots on the bottom plate of the head.
When you remove the burned belt determine the cause. Will the brush roll freely or is it jammed with hair and fiber?. Clean the burned rubber from the motor shaft before replacing the broken belt, available at a vac specialty shop.
Sep 04, 2009 | Vacuums
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
