Question about Fujitsu fi-5750C Flatbed Scanner
How do you get to the motor/gear on the flatbed transport ? .. That is, how do you disassemble it?
  • 3,866 Answers
Okay this would need to be taken apart from the bottom there are a few screws there to deal with once that bottom is off you will have access to more then just what you want and or need there to get the job done.
You might encounter some lock snaps if you do just use a plastic wedge, Hence this is it does not come apart after you removed all the screws.
Another way witch I do not recommend is taking a plunger and applying force on the glass and pulling up gently to open up the glass part but you will need some adhesive later and that becomes a big mess.
So i hope i gave you some ideas here I wish I could make diagram for you but there is no where I can put it on a forum based website, However if after you unscrewed everything or you just did not find screws or what not please do not pry this open with a wedge if new screws where underneath I would recommend bring this to a printer/copy tech so they can use the proper tool to open this. But 9 times out of 10 this is screwed down.
Thanks for you Rating last time I so much appreciate that!
If you like this advice please do Accept and rate like you did before thanks!!
Posted on Sep 23, 2009
Konica minolta 250. Make a noise in demarrage and stop printting
Check Fixing drive gear or Transport Motor on back lower side.
must be worn out,
Drum Gear or developing gear also gives such an issue
Jul 16, 2017 | Konica Minolta Office Equipment & Supplies
How to reset Samsung WB30F digital camera
A reset will not reset the lens zoom transport only a strip down to see the transport motor and gears
Sep 10, 2014 | Samsung Cameras
It does not respond light for paper and warning sign are lit and blinking
If you have a paper fault with no paper in the paper path and the paper transport rollers are not turning.
When one removes fuser, all colour drums and transport belt there is a shutter over a set of photo cells. Clean these. Vitally this shutter is driven by the paper transport motor turning in the reverse direction. The gear for this is at the right hand end of the fuser bay. Turn the gear until the shutter opens and a clutch clicks. Reassemble, power on, everything worked.
There is no mention of this shutter anywhere in troubleshooting or where the home position of the transport mechanism is.
The good thing about this finding is that should the same problem re-occur I will only need to remove the fuser unit and turn the gear.
Hope this solution helps.
Aug 16, 2011 | OKI C3100 Led Printer
Toshiba E-Studio 600 Error Code Cd 30?
Your copier has detected an abnormality in the used toner transport motor. Make sure there is nothing stopping the motor from turning ie. stripped gears, toner build up. You may have to clear out the transport system or replace the motor itself if it has weakened.
Aug 28, 2010 | Toshiba e-Studio163 Copier
Code error CD2
Aug 23, 2010 | Toshiba E-STUDIO 550 Copier
Error code CD2 copier Toshiba eStudio55
Aug 23, 2010 | Toshiba E-STUDIO 650 Copier
Scanner has racheting noise and red light stays
This noise is caused by the transport lock. Power the scanner off. Lock and unlock the transport lock a few times and then leave it in the unlocked position again and power on.
Nov 20, 2009 | Epson Perfection 4180 Photo Flatbed...
My scanner could not start after transporting it without locking. SOME BODY LOOKED AT IT AND SAID THE PROBLEM WAS WITH THE MOTOR. HOW CAN I GET THE MOTOR.
Possibly the lock button got moved in handling - look under the front of the scanner for a small button that moves sideways - it will have a lock and unlock position. It may have moved to the lock position - that prevents the head from moving.
Oct 24, 2009 | Canon CanoScan 5000F Flatbed Scanner
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Jan 22, 2009 | Office Equipment & Supplies
Please help me
C2550 = Drive Motor Problem.
Try to reset it first. Enter the numbers "10871087" on the keypad. Enter 906, press start, Press Execute on the touch panel. The machine will reboot.
If it comes back, you may have a bad drive motor.....or something else is dragging it down. Check that the developer unit turns. Check that the fuser unit turns. Check that all the gears in the transport unit turn. Maybe one has a bad tooth.
There is a double gear that sometimes causes the metal to flex on the transport unit frame and it doesn't mesh like it should.
Jul 29, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
Fujitsu fi-5750C Flatbed Scanner Logo
77 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
