Question about GE PSS26SHRSS Side by Side Refrigerator
GE GSS25JFP too cold on freezer side and WARM on frige side . I noticed the refrigerator too warm last week and is getting worse. Ice maker fills fast and won't operate since cu8bes solidify. The two temp control knobs do not make any difference unless I shut them off. Then I have nothing.
  • 4 more comments
  • jbjb449 Sep 23, 2009
    I removed the freezerfood and one large panel behind . There remains the light assembly and ice maker, am I in the right area of this defroster?
    where is the defroster heater located? thanks.
    They look kind of like that tinsel string on a Christmas tree, right? Yes the lower ones do have ice on the tinsel part. The upper ones appear to be ice-free.
    Okay I've turned the freezer "off".
    The ice has melted from the coils. How do I keep it from returning?
    give me some time before closing case. This is my first "reefer" job. Tanks I'm on the right track.
  • 8,197 Answers
GE side-by-side refrigerator - Model GSS25JFP
Remove the rear panel in the freezer and see if the evaperator coil is clogged with ice, if so you have a defrost problem, the food compartment gets its cold air from the freezer and this ice blocks the air flow. Check the defrost heater,, it is glass, and is most likely your problem.
Posted on Sep 23, 2009
Our frige and freezer keep warming up. The Ice in the ice maker melts and then refreezes, causing our freezer to fill up with icicles. This has been happening for about a week now. We moved about two...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side is working fine but the refrigerator side is warm and not cooling well
its normal for a frige to get warm when its new run wait until your evaforating section is full of ice then you will notice that side of your frige will get the normal heat.... to stay in automatic mode
Aug 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side Refridgerator (Artica) model PSC25MSTA. Freezer and refer side not cold. Noticed coil under ice maker hot. Did a test on ice maker per GE web site instructions, Tested OK. Noticed cold...
No,what it appears to be isthe evaporator is freezing over and hindering air flow. The water under the ice maker is actually condensation because the ice maker is colder than the cabinet temp. The unit should have an automatic defrost so it appears it is cycleling through yhe defrost. Unless you call out a tech to set the defrost timer, all you can do is unplug it and defrost in its own. Was the door ajar for any period of time? not completely closed? That will also do it because of humidity. The moisture in the air will freeze. The refrigerator side cools from bleed over from the freezer.
Oct 10, 2009 | Refrigerators
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfhjsf
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a G.E. mod.# GSS22KGMCWW refrigerator that frosts
you have defrost problem 1 timer 2 defrost thermostart 3 heater best way call service
Apr 05, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
GE PSS26SHRSS Side by Side Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
