Question about Tannoy Precision 8 Main / Stereo Speaker
I HAVE A SYSTEM 8 STUDIO MONITOR ONE SPEAKER DOESNT REPRODUCE ANY LOW END they've been stationary for 10 years
    Novelist:
  • 169 Answers
It could be the driver or it might be the crossover, if you are happy take the driver out and check it with the amp on LOW volume. If it is blown it should be possible to get it re-coned or repaired. If the driver is ok then next step is to check the crossover.
The crossover divides the full range signal to hi and low, it will be made up of colis and capacitors with some soldered joints, there may be a faults with this. If it is a loose connection / dry joint it is easy to fix.
At all steps write down what you are doing, as this will save time and money at the repair shop.
Hope this helps, thanks for using Fixya
Posted on Sep 24, 2009
What ohm and watt speakers can I use with a craig CM402 cd am fm player? It came without them
Speaker requirements are likely to be 8 ohm, most modern hi-fi speakers are. A few low-fi systems have used special high impedance speakers and the old hi-fi standard for valve amplifiers was 15 ohm and 3 ohm or lower has been used in televisions a lot.
4 ohm speakers are commonly used where a higher power output is desired at the cost of some quality of sound reproduction but depending on how the sound is listened to can soon overload some amplifiers primarily designed for 8 ohm as it will try and deliver more power into the lower impedance speakers and perhaps exceed the rating.
8 ohms is a safer choice. The lower the wattage rating of the speakers the more efficiently they tend to be able to reproduce sound at low volume levels so for background music in a small domestic environment the average power requirement will be in the order of half a watt so even with a high powered amplifier the volume would rarely be turned up above 1 - 2 on the typical scale of 10 and ten watt speakers would be more than adequate. It is unfortunate that it is almost impossible to obtain quality speakers rated at such an unfashionably low power rating.
With the stiffer cones of a higher power rated speakers the volume has to be turned higher before the speakers become efficient and listening at low levels can be difficult. In a domestic environment a 50 watt rating is perhaps the best compromise as if there are neighbours to consider a ten watt average power output will be sufficient even if the amplifier is capable of higher powers. Just don't turn the volume up more than necessary.
The greater the power rating the more power will be required for efficient reproduction. For electrical and mechanical safety of the speakers the rating should exceed the maximum output of the amplifier but listening at low levels with quality of sound can become virtually impossible.
It is all a matter of taste and environment.
May 30, 2016 | Craig CD Shelf System with AM/FM Stereo...
I put a sub in my 2002 Altima but when I turn it up the bass cracks on the door speakers??? What do I do to get all the bass on the sub
Hi Ethan,
What you're looking for is called a "crossover". A crossover is an electronic filter for an audio or speaker circuit. In an audio circuit, a crossover is used to prevent or pass certain frequencies or a range of frequencies from passing through it. Since your sub will reproduce the bass or low frequencies, you don't want other speakers to reproduce them. A band pass filter on your door speakers will do this for you. A band pass filter passes only a range or "band" of frequencies and blocks those that are above and below the range or band of frequencies selected. Installing a band pass filter will prevent the very high & very low frequencies from getting to the door /dash speakers. Likewise, you should consider connecting a low pass filter to your subs, too. The low pass filters work a little differently from of the way band pass filters work - they only allow low frequencies to get to the sub - blocking all the other higher frequencies (your other speakers are better suited to reproduce those). Lastly, you would install a high pass filters on tweeters. Tweeters are designed to reproduce only the high frequencies - sending mid and low frequencies to them is wasting power and can cause damage to them.
You purchase the filters for specific crossover points (the block / unblocked point) as determined by the individual speakers. If a sub has a frequency response of 20Hz - 100Hz, a low pass filter of 100Hz would be ideal. Remaining filters would need to begin at 100Hz - assuming the mid-range speakers have a frequency response beginning at 100Hz. A band pass filter of 100Hz - 3KHz would fit the bill nicely if the mid-range speakers go up to 3Khz Match the high end of the band pass to the high end of the frequency response of the mid-range speakers. Next, a high pass filter at 3KHz would allow only the high frequencies to your tweeters. Basically, you want to have the entire audible range 20Hz - 20KHz covered by the speakers and have the crossover points that match the frequency response ranges of the speakers.
I hope this helps & good luck!
Apr 12, 2012 | Pioneer Car Audio & Video
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Changing the omes of a 4 10'' bass cabinet
i guess ur talking about four nos of  4ohms 10" speakers. two speakers of four ohms connected in series gives 8 ohms, but if u use parallel connection u will get half of individual ohms i.e 2 ohms. so connect two speakers in series and another two speakers in series. parallel the two serial speakers and voila... u get a 4ohms speaker with double the wattage.
parallel connection - connect +ve to +ve and -ve to -ve.
series connection - connect -ve of one speaker to +ve of another speaker so that u have +ve input to one speaker and ground(-ve) on the second speaker.
So, two separate series speaker then parallel the two series speakers.
Mar 12, 2010 | Audio Players & Recorders
Lost low end
Fuse don't break when the blow. If they blow you get NO sound, not distorted sound.
I think you need to bite the bullet and move on with isolation of the (probably dying) woofer. Remove it and swap it with the other one to prove it. Observe the polarity of the + and - wires on the back of the woofers.
Apr 27, 2009 | Audio Players & Recorders
Samson Rubicon 5 Studio Monitor speaker is Popping
It seamns like its pretty commom =(
We should organize and complaint with samson!!
Read this:
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html#post5794093
Mar 12, 2009 | Car Audio & Video
Hooking up speakers to MacPro
goto straight to the aja card if its final cut pro compatable and upto date.   Look for studio monitors, a good brand for instance yamaha hs80m 8inches that have built in amp other wise you'll need an amp generally for studio monitors.
Jan 25, 2009 | Computers & Internet
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
Tannoy Precision 8 Main / Stereo Speaker Logo
103 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
shaqsatin
Level 1 Expert
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
