Question about Kenwood KFC-W300S Car Subwoofer
My kenwood kfc-w300s sounds like its clicking but it sounds like its the magnet, when i hold the magnet it doesnt click but wen i let go it carrys on, Any suggestions?
  • 43 Answers
THE COIL IS BLOWN, THAT HAPPENS WHEN YOU OPEN THE TRUNK WHILE BLASTING YOUR MUSIC, IT'S USED TO A CLOSED INVIROMENT THEN BLASTS OPEN, NO GOOD FOR THE SPEAKER.
Posted on Sep 23, 2009
Kenwood amplifier A-94 makes clikkeng sound wen u first turn it on
Kenwood 94 Service Manual Stereo Integrated Amplifier Found this link, manual will cost you $5. That will help with troubleshooting. Sounds like leaking power supply capacitors, once they warm up they do not leak as much. Could also be speaker protection circuits, make sure there are no shorts in the speakers or their wiring. Find someone who knows how to use a voltmeter and a soldering gun. Be prepared to hand him/her cash and a large thank you.
May 02, 2014 | Kenwood Audio Players & Recorders
How to repair kenwood KFC-ws253 subs
This usually means the voice coils have burnt out also.
When I was with Kenwood, it wasn't worth spending the time to repair units that had been overdriven (i.e. burnt out).
Mar 02, 2013 | Kenwood KFC-WS253 Car Speaker
The led on my kenwood KFC-W3534A won't come on
It can be the issue with connections or power issue or also the board issue.In some cases all checked out ok,but the actual problem comes out to be the short is display panel,which power the led.------Also how old is unit and what exactly caused this problem,is there any kind of other indication showing up like,loose wire or erratic noise coming up,with no power .Etc etc,,-------Click this link below :----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Kenwood Car Audio & Video
Operation manual for Kenwood KDC 139 cd player
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jun 22, 2010 | Kenwood KFC-1390ie Car Component System
What amplifier do i have to used for the kfc-w3009
I run my Kenwood KFC-W3009 from a Tornado 5 channel amp via a cross over . Amp is 2000w 4 channels are for the 6X9's & the 5th channel is only for sub. I will never sell that amp as i kicks. I use it in my 15 seater bus & people can hear me coming down the road
May 11, 2010 | Kenwood KFC-W3009 Car Subwoofer
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
How do i wire 2 4ohm single coil subs to a 2 channel 6ohm load?
If you can setup the Amp as a Mono Amp this will work for you very well unless the Amp needs a 12ω Load when setup for Mono Operations. You will want to hook the Two Subs in Series so that the Amp will see 1 8ω load. This means you will hook a wire to the Positive pole of one Sub and hook the Negative Pole to the Positive Pole of the Second Sub and hook the Negative Pole to the Amp's Negative pole. This will reduce the overall output but will end up having better reliability of the Sub since each sub will only see ½ the overall output of the Amp and you will still get the full output of the Amp.
Oct 16, 2009 | Kenwood KFC-W300S Car Subwoofer
Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
I NEED USER MANUAL OR SPECS. TO BUILD PROPERLY SIZED CABINETS
Can't help you on the manual, but basic specs for both drivers are listed on crutchfield.com web site.
Easy way to do it is ; type in KFC-W2505 and the KFC-W2509 in your search engine and click on the Crutchfield web site. This will give the overall cubic dimensions of the cabinet, plus other info. Hope this helps...
May 02, 2009 | Kenwood KFC-W2505 Car Subwoofer
Kenwood KFC-W300S Car Subwoofer Logo
99 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
