Question about Canon ImageRUNNER 330s Copier
What the codes means
Error code E677
    President:
  • Canon Master
  • 990 Answers
Hello sir; The error code E677 it means " problem in communication between printer board and image processor board" , my suggestion is check all the conector between these two boards.
Posted on Sep 23, 2009
What to do Error E677
hello i will tell you what error means and how to fix the problem but you will need the service manual to help you
1. E677 error means that "The communication between the printer board and the machine has a fault."
2. Check the connection between the
printer board and the PDL I/F
board and the system motherboard.
Is any of the pins bent or otherwise
not normal?
3. If this not helped you must replace the printer board
You can download the service manual for ir400 from the below link it will save u $$$:
http://goo.gl/bFmfmN
good luck
Sep 11, 2013 | Canon imageRUNNER 400 Printer
Errors codes E677 & E005 trying to find a total usage counter for all copies done on the machine
e677 might just be a bad drum. E005 is the cleaning web that needs replaced. The counter is in the upper left side behind the front cover!
Dec 20, 2010 | Canon imageRUNNER 400S Copier
E677
E677 refers to an error in communication between the printer & image process board, there would be sub codes 0001 through 0006. check for a loose wire or connector between them
see for blown parts on boards fix them or replace them ( the second).
hope i help
Dec 02, 2010 | Canon imageRUNNER 400S Copier
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
My canon 330s says switch on and off and there is a code e677 what do i do?
this error code is related to the optional printer board and interfaceboard contact ur nearest service center as the technician will open the machine and disable the board or changed it.hope this will help
Oct 10, 2009 | Canon ImageRUNNER 330s Copier
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Eror E677
roblem :
The machine displays an E674 code. This may be followed by an E677 code when the Fax pcb is removed. The imageRunner also has a Print Board installed.
Solution :
With the Fax Board and Print Board installed an E674 code occurred. When the Fax Board was removed an E677 code then occurred.
Try removing the PDL Interface pcb for the Print Board from the copier. Reinstall the Fax Board, if the E674 code does not occur and the copier is capable of sending and receiving faxes, then replace the PDL Interface pcb because it may be faulty and causing the two E codes; E674 for faxing and E677 for printing.
Jun 01, 2009 | Canon imageRUNNER 400S Copier
Error 677
An error code E677 with a subcode of 0004 however, may be caused by either an overheating CPU or low voltage being supplied to the printer board. Follow the procedure indicated in Technical Publication CIB-T052 for those printer boards which continue to exhibit error codes of E677 with a subcode of 0004.
Note: Since error codes E677 were reported frequently with different subcodes, Canon decided that all boards be screened. After the screening a colored dot was placed on the board near the AUI port. As of now, a Yellow dot means that it has passed screening and should work. Eventually the board will be modified and the dot will be Red showing the board has modification and has passed screening.the problem is a connection problem between the printer board and the machine..
the first thing i would do is check and reconnected the printer boards and the connection box they plug into..witch is at the rear of the machine .. would not do software until i found out what the problem is...i have found one machine that the connection box did not have a outside cover so it would not hold the boards tight...
Mar 25, 2009 | Computers & Internet
E677
press the additional * 2+8 additional *
select the copier on the screen
select function
select clear
select ERR
press OK
restart the Copier
Oct 02, 2008 | Canon imageRUNNER 400S Copier
CANON IR 400 COPIER - ERROR - E677
Sep 11, 2008 | Canon imageRUNNER 400S Copier
122 people viewed this question
old marine
old marine
