Question about HP 32sII Calculator
WILL NOT TURN ON
IT WAS WORKING FINE AND AFTER A CALCULATION IT FLASHED THE DIVIDE SIGN AND FROZE. I TURNED IT OFF AND IT WILL NOT RESTART. I TRIED REPLACING THE BATTERIES AND IT STILL WILL NOT TURN ON.
  • HP Master
  • 7,993 Answers
Adjust contrast : Hold down [C] key and press [+] to increase contrast or [-] to decrease it.
Diagnostic tests (from the Users manual)
1. Hold down [C] key and press [LN]; may have to repeat several times.
2. Press and hold down [C] key and press and hold down both the square root key AND the Sigma + key. When all keys are released, MEMORY CLEAR is displayed.
3. Remove batteries and lightly press a coin against both battery contacts in the calculator. Iy should say MEMORY CLEAR.
If these steps fail to restore calculator operation, it requires service.
Hope it helps.
Posted on Sep 29, 2009
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
Dividing 2 different scientic equations into another
Sorry but you are using the word EQUATION incorrectly. All you have is two numbers you want to divide one by the other.
Enter the numerator 1EE (-) 14, press the division key / then enter the 5 EE (-) 12. Press the = sign.
Note: to enter the negative sign in the exponents, use the change sign key marked (-), (+/-) or [+/-] . Do not use the regular MINUS sign.
When you use the EE key, you must not enter the 10. It is understood because EE is a shortcut for *10^.
Apr 06, 2014 | Texas Instruments TI-30XA Calculator
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
Laptop froze now wont restart
remove the laptop battery and turn it on now check the led indications
May 09, 2012 | Toshiba Satellite Computers & Internet
I am dividing a 3*1 matrix with a 3*3 matrix with numbers in polar format and it gives me the error data type error.
You'll get the same error if you try to divide two matrices with real numbers. The TI-89 doesn't allow you to divide a matrix by another. However, you can multiply a matrix by the reciprocal of the other.
For example, to calculate A/B, calculate instead A*B^-1 . Makes sure you use the (-) key just to the right of the decimal point key to put in the negative sign before the "1".
Sep 10, 2011 | Texas Instruments TI-89 Calculator
96 divide by 12
Unless your calculator is wrong the answer is 8. but I think you wanted to ask that the calculator gave wrong results. If so remove and clean the pads, warm off the pads, clean battery contacts and reset.
Mar 29, 2011 | Casio FX-300MS Calculator
Ti-89 Titanium froze
Try pressing the "on" button.. simple i know but I tried cancel, quit, esc, off everything.. but pressing the on button worked..
Occa
Nov 09, 2008 | Texas Instruments TI-89 Calculator
BASIC ADDITION
hi,
I had one that did that. equals turned out to be for multiplying and dividing . try to hit plus( + ) sign again instead of equal for the solution.
hope that helps
J
Aug 07, 2008 | Canon P170-DH Calculator
Dividing numbers
Turn the calculator off. Hold down the shift key and then turn on. "Shift" should dispay on the screen. Now press the memory button with "5/4" on it. You can choose between "cut", "up" and "5/4".
Jul 12, 2008 | Aurora Electronics PR600 Calculator
TI-84 Plus: Calculator Unresponsive
Try pressing the "On" button a couple times. That should work
Oct 27, 2007 | Texas Instruments TI-84 Plus Calculator
HP 32sII Calculator Logo
326 people viewed this question
Seeker5211
Seeker5211
