Question about Samsung BIXOLON® STP-103 Printer
Samsung STP-103 Thermal Printer will not print lines correctly
I have an "ALGE Timy" timing computer connected to a Samsung STP-103 printer. Both units use ASCII 1 start, no parity, 8 data,1 stopbit.
Yet when printing each line of information (which is set to 21 characters) the print carries on without starting on a new line (like it has not seen the stop bit, tnnew line). I have tried changing the dip switch on the back of the 103 which give two options for how many characters per line but neither works correctly only the character spacing changes.
Your suggestions.
Cheers
Tony
    Problem Solver:
  • 18 Answers
Wow, serial communications still in use. Naturally, both units have to use the exact same protocol N81 for instance, so make certain the sending unit is set to the same, then check the cable to verify that the appropriate pins are connected and or crossed. I believe your symptoms can be caused by using hardware handshake and having pins 6,8,20 (20 only if a 25pin connector) shorted on the printer end. If possible, you can try switching both devices to software handshake.
Posted on May 07, 2017
  • 32 Answers
SOURCE: Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Posted on Aug 31, 2007
SOURCE: When switched on, printer makes starting noise and the stops.
check the fuser unit
Posted on Apr 24, 2009
  • 406 Answers
SOURCE: my samsung clx-3160 colour laser printer does not
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Posted on Jun 29, 2009
xptareq2000
  • 1447 Answers
SOURCE: Samsung SCX-4521F / Fuzzy thin lines when printing from PC.
If your toner cartridge is very old please replace it or it new clean scanner unite all mirror with glass cleaner or cystal cleaner.may be fix your problem.
Posted on Jan 23, 2010
SOURCE: Printer LCD "Replace/Install Toner Waste Bin
I have just now, taken the waste toner bin out, squirted in some hand soap and water. Shook vigorously and rinsed it out. the CLX-3175 is working a treat again !
Posted on Jul 31, 2010
Samsung SCX-4521F All-In-One Laser Printer Problem: internal error H6FW/xl_image Line 482 started to come up in every printing job from different computers running Win 7 (32/64) on the home network. The...
If every thing is setup as DHCP, look at the routers log and see what Address the printer is on. Then bring up the printer properties and check the port settings. If all is correct, remove the printer and reinstall the driver.
Feb 23, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
MI THERMAL PRINTER DOESNT OPEN THE CASH DRAWER I CHECKED THE BOXES FOR THIS OPTION I CLICKED APPLY AND ACCEPT AND IT REMOVES THE CHECK MARK FROM THE BOX WHAT DO I NEED TO DO?
I think this printer has a cash drawer open version and a standard non-cash drawer version. Make sure you have the right model of the unit. If the setting on the driver is not "holding" it is likely a user access setting issue (UAC). make sure you have admin privileges. Depending on what type of windows you have it'll be different.
Apr 20, 2010 | Samsung BIXOLON® STP-103 Printer
Problem in print
Sorry i didnt get you but i assume that your printer is printing junk charaters ? If this the problem than please try to uninstall printer and reinstall its drivers and than try to take print. and If still you didnt get rid of it than try to change the printer cable. this will definately resolve your problem.
Jan 16, 2009 | Samsung STP-131 Thermal Printer
On Line Error
maybe..online error usually is a communications issue..you might want to isolate the printer from the computer power line, if that's an issue.
Aug 19, 2008 | Samsung ML 1510 Laser Printer
Zebra 105Se missing line
Try cleaning the thermal printhead. Zebra makes thermal printhead cleaners or you can use a qtip and some isopropyl alcohol.
Make sure the printer is turned off before doing this.
May 19, 2008 | Zebra 105Se Thermal Printer
Samsung BIXOLON® STP-103 Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
