Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony WEGA KV30HS420 shuts itself off
Actually we have had our TV since January 2005. Just in the past month it turns off by itself. We can turn it back on, but at the next commercial it turns off again. The weird thing is sometimes it can go an entire day without turning off, other times it turns off after the first 20 minutes and keeps turning off every 5-10 minutes. Picture is perfectly clear when it is on.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    No, no capacitor, no relay is bad in this tv.
  • margaret thornby Mar 06, 2012
    This same exact problem just started with our tv and we bought it in 2005 also. Am just wondering what you ended up doing to solve it?
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Posted on Aug 11, 2010
  • Sony Master
  • 3,866 Answers
Okay, Best adivce in town by a Qualified Tv repairment since 1992.. You got maybe a couple of bad Capcitors in there or a bad overheated relay
Posted on Sep 23, 2009
  • larryarice Sep 27, 2010
    So what is the cost to fix this? Should we fix it or just buy a new set.
4 Suggested Answers
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
  • 586 Answers
SOURCE: T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Posted on Dec 25, 2007
SOURCE: sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Posted on May 01, 2009
Sanyo tv turns itself off
Power supply failure
Jan 29, 2014 | Televison & Video
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony wega engine 3lcd. turns itself off
It must be dlp tv that use lamp, is it?
If its true then replace lamp in tv that reached to end of its working life span and causing problem.
Your question shows it is CRT tv but symptom says it would be dlp tv.
Let me know if you have additional question about tv.
Jul 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
We have had our TV since January 2006. Just in the past month it turns off by itself. We can turn it back on, but at the next commercial it turns off again. The weird thing is sometimes it can go an...
If it is Sony KDF-42WE655 model then it sounds TV needs lamp.
Have you replaced its lamp since 2006?
And please check when TV gets off itself, does its standby red light blinks? if yes, how many times it blinks? This is an error code.
Let me know to find out any possible solution.
Thanks.
Sep 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
The tv turns itself off constantly usually sfter 7PM and mostly when commercials come on, iturn it back on, then it goes off at the next commercial. sometimes stays on for hours without going off, then it...
your tv off own its own, because its regulation varies, the voltages changes at the output of your power supply, take your tv for repair immediately before it burns more components outside the supply. ask your technician to connect a avo meter at the output of a supply and observe for along time, he will notice a change. thanks
Mar 27, 2009 | Sony 32IN TV Stand Designed for Model...
Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
2,429 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
