Power Supply my system's power supply is not starting and so as my system
  • 34 Answers
There may be several problems.
1. power supply may not be connected
2. the voltage switch may not be in its correct position on 110V or 220 V
3. bad wire broken
4. not connected to the internal system
if the problem is other than these then i can not solve them unless the PC is in front of me
Posted on Dec 15, 2007
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Alienware aurora desktop with 525 Watt Power Supply was working fine then all of sudden started making a loud noise like it was going into overdrive or something then emitted a horrible like burning...
The switch mode power supply in the desktop computer has failed. Most likely the capacitors in the power has exploded.
You need to open the desktop computer and remove the old power supply and replace it with a new one. Take the old power supply with you to your friendly computer shop and get a replacement power supply with the same wattage or greater wattage.
Jul 25, 2010 | Alienware PC Systems Alienware True 480...
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
There is no start
Find a electronics-technician with a MultiMeter, to measure the output voltage and amperage being produced by the power-supply, and compare with the specifications for the power-supply..
Or, replace the power-supply.
Jan 13, 2010 | HP-COMPAQ - 243891-002 (243891002) Power...
Power drops aprox 1 minute after start
Good day!
It's the power supply, usually the fan of power supply run once it start normally, Replace the power supply. And try to turn on the unit.
Feel also some part of the mother board if they are hot like the heat sink the power supply casing do it when the power is off.
Thanks.
Nov 06, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Problems with hipro pc power supply
sound like the regulator in the power supply is bad.
need a new power supply.
Oct 15, 2008 | HP (152769-001) (152769001) 250-Watt Power...
No Power
Dear Sir,
I assume, you have voltmeter with you.
Set VOM to DC 20 V range.
Remove the Power Supply from cabinet. Be sure you have proper earth in your house/workshop.
On the 20/24 pin main connector of your power supply, short the pins carrying green & black wire.
Hook your voltmeter -ve on any black pin of the connector permenantly.
& then connect the mains power cord to your power supply.
If your power supply is ok, this shall start the fans of the power supply on & running. Now you can check the voltages on different pins. There is a sticker on your power supply showing the normal voltages on every wire.
If you don't see any / normal volatges, your power supply needs repairing. You can buy a new one/ repair existing.
Jun 17, 2008 | Silverstone SST-ST405 (SSTST405) 400-Watt...
Orange flashing lights
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Mar 18, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
Computers & Internet Logo
801 people viewed this question
Alun Cox
David Payne
David Payne
