Should i go through the crossover built in and
Should i go through the in on the built in crossover then out of the crossover to my mackie 300z's. everything is powered by a qsc 2450 amp.
Thanks!
  • theheis Sep 25, 2009
    i am using a qsc 2450 and i would like to use the built in crossover on my behringer 1800x then the output to my behringer 1520 one one channel. note i am only using 1 sub which is a behringer 1800x on one side with a 1520. the other will only have the 1520.
    will this be o.k.! for sound that is? going through the built in x-over to my 1520?
    thank you!
    sincerely,
    Scott
  • 4,234 Answers
I'm not sure what you are trying to accomplish here, but there are 2 types of crossovers. One is designed to handle full speaker power and is built into the speaker cabinet, the other is designed to split the frequencies PRIOR to amplification. Can you better describe what you are trying to do and the equipmetn you intend to use? That will allow me to detail the setup for you.
Thanks,
Dan
Posted on Sep 24, 2009
How to connect power subwoofer mackie
Take the mono output from the desk to the powered subwoofer, it should have it's own crossover/low pass filter built in.
Jan 30, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie srm450 v2 no top end.
Check the aspect of the crossover filter for the speakers, inside. Sometimes they fry.
Apr 14, 2014 | Mackie SRM-450 System
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Sep 23, 2013 | Mackie TH-15A Active DJ Powered THUMP...
I have a mackie cfx12 mixer. I just added an eq with sub woffer crossover via the main inserts using the proper insert cables. System works great, however when Using a CD player the subs will not work. any...
Sorry, I have looked at the schematics and the TAPE IN jacks are mixed into the MAIN outs AFTER the insert jacks, so your subs will NOT receive signal via the insert from the TAPE IN jacks.
You could make a small passive mixer merging the TAPE/CD before going to the crossover. This would require some non-standard cabling.... The other option is to run the CD into a regular stereo channel rather than the TAPE IN jacks... then the CD will go through the insert/crossover and to the subs as you desire. The last option is to use the crossover at the MAIN outputs instead of as an insert... which would be the CONVENTIONAL way... use BALANCED cables wherever possible.
Jul 22, 2011 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Hello, i really don't have a problem i just want to learn how to setup my system the good way. i have a mackie cfx 12 mk ll mixer, a dbx 233 xl crossover, 2 mackie fr 2500 power amps, 2 harbinger HX...
I can't give you much information other than to tell you the idea of adjustable crossovers is to allow adjustments to suit the acoustics of the room or space where they are sited, a function that used to be common but has largely been replaced by the graphic equaliser, popularly used to adjust the sound to suit personal preference but originally was intended to be used with a white or pink noise generator and adjusted to compensate for mechanical and electronic "inefficiencies" of hi-fi systems to produce a pure sound.
The best advice I can offer you is to start hanging with a few hi-fi nuts to learn what you need to know and lots more. Positioning the speakers is very important for a good sound and popular and inexpensive mod is to fit spiked feet to them or lift them clear of the ground on purpose built stands...
Jun 18, 2017 | DBX 223xl Active Crossover (Stereo 2 Way...
I use a Mackie 1604vlz board. I have Passive EV Speakers that I use a QSC power amp for. I want to add one Powered Subwoofer to this. How can I hook up without buying a crossover? Can I run out frome the...
You can, but I would not suggest it. Depending upon the input design of the powered sub, the highs might not get filtered out. Many subs assume that they are only receiving the lows. You are better off using a crossover between the mixer and the amp for highs and the powered sub for the lows. Please note that the crossover will give you much more control over the sound quality.
Dan
Mar 29, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
No sound from horn of mackie SRM-450
http://www.youtube.com/watch?v=8jYY3kHj1U0
Apr 04, 2010 | Mackie SRM-450 System
Where is the crossover located in the mackie srs 1500and does the crossover have a fuse.
The Mackie SWA1501 has an active electronic crossover on its main circuit board.
Jul 15, 2009 | Mackie SWA1501 Subwoofer
50 people viewed this question
 Grubhead
Grubhead
