Question about Feber Roadster Waverazor Battery Powered Childrens Car
Hello, dont really no what im looking for or if you can help me but my little girl has a feber quad, and the cogs on the gear box??? have gone apparently which means when the pedels pushed down the cogs arnt turning to make it move?? wondering what parts i need and where i can get them from. email address is littleali666@hotmail.com thankyou!!
  • 33 Answers
Try ebay theyr very good for these
Posted on Sep 29, 2009
Ac don't blow cold only Luke warm and heater don't blow hot only warm what could it be help please
If this is a Ford vehicle it likely is a stripped gear in the blend door motor, which looks like a 4x4" box 1" thick held to the heater plastic box with three or four screws. This part can be ordered online for about $30 and is not difficult to replace on most vehicles.
The wires have a connector that is fairly easy to pinch and pull to release. The little motor box can be unsnapped and opened to view to see if the gear is not engaging or is missing a tooth before ordering the replacement. There will be grease on the gear so have a rag handy to wipe it to be able to inspect for damage. The identical cog gears are extremely difficult to find so don't waste your time trying to replace the little cog that strips out in these.
Mar 14, 2015 | AC Cars & Trucks
I need help asap 2003 Expedition code p0171 and code p0712 i have and idea of the 1st code but whats the secound code i really need help i dont want to take it to a shop where there going to charge me alot...
P0700 Transmission Control System
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System -Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Pedal Position Switch -Circuit Malfunction
P0705 Transmission Range Sensor/Switch Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor/Switch Circuit Range/Performance
P0707 Transmission Range Sensor/Switch Circuit Low Input
P0708 Transmission Range Sensor/Switch Circuit High Input
P0709 Transmission Range Sensor/Switch Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine RPM Input Circuit
P0726 Engine RPM Input Circuit Range/Performance
P0727 Engine RPM Input Circuit No Signal
P0728 Engine RPM Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit
P0741 Torque Converter Clutch Solenoid Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
Now i dont know a lot about automatics especially modern ones with all this fancy electronics thats used nowdays but i think its a fault with the temperature sensor for the gearbox.But where its located and what it looks like i have no idea it could even be mounted inside the gearbox .Sorry not a very good answer from a mechanic but?? very few of our europeon cars come with auto transmission .Evan when i do know whats wrong i cannot buy the parts for the gearbox as only re-con boxes supplied by the dealer so best advice is to try a specialist in auto box repairs only .PS some of my best students when i used to teach mechanics many moons ago were the girls so no excuses like iam only a girl please
Apr 22, 2013 | Cars & Trucks
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
Where do I get a gear box for injusa 12 volt quad?
Sales@robbietoys.co.uk
I'm ordering new cogs £7.20 inc. p+p Bargain
Nov 26, 2010 | Injusa Mega Cyclops Quad 12v 2 Motors...
I need a cog for dareway silver 6 volt
Phone 0844 561 0008
That is Feber's number. I just phoned and they were very helpful.If it is under warrenty then they are great. And if you need spare parts they have them all.
Oct 29, 2010 | Feber Roadster Waverazor Battery Powered...
Hello, Im looking for a part number, I was
The parts department at any VW dealer would be happy to show you an illustrated parts breakdown on the car. That way with just a little time and effort effort you would know the name of it, the part number, the cost at a dealer, and the amount of time required to install it. Most likely you are going to have to buy the entire wiper motor assembly, you will not be able to get internal parts, and they could give you the price on that as well.
Oct 28, 2010 | 2001 Volkswagen Golf
Hi, looking to buy a new 6v battery for quad bike. there are no stickers on it to identify which brand it is, apart from feber.
Feber makes ride-on toy cars and bikes and also resell batteries made for them under their own brand/logo.
Any good brand of equivalent (Sealed Lead Acid or SLA) battery with the same voltage (eg. 6 Volts) and equal or greater Amperage (e.g. 12 Ah) and approrpriate terminal connections and physical size limitations (must fit the battery compartment) can be purchased as long as a good warranty is given. A higher the Ah rating will result in a longer runtime with the converse also true!
Hope it helps! Let me know if the information is useful.
Aug 10, 2010 | Feber Roadster Waverazor Battery Powered...
I have a 1998 Gt Aggressor 26" bicycle. When shifting in the large gears, it hesitates before shifting or does not shift at all and just clicks. Can you help?
sound like the shift adjustment need moving or the cable to be adjusted from gear shift to the cogs there are a couple of ways to do this first select the low gear so the cable is slack and then look where the cable connects to the cog shift if you loosen the nust holding the cable and pull a little cable through retighten and try shifting.. if this doesnt work look at the way the guide moves the chain across if you see the guide stopping before the chain goes onto the cog look closely and you will see two small screws on the arm one is to stop the guide going to far to the right and one to the left look at the one on the right that shlould be the one for the transit to the large gear cog if you undo the screw half a turn then try the gear shift again see of it move far enough to put the chanin on the cog if not undo a little more.. these screws work for both the small and large cog shifting so the same can be done for the small cog if the chain keeps coming off.. Good Luck A
Aug 04, 2009 | GT Bicycles Cycling
Small unnamed quad, prsumed 49cc, wont fire only clicks.
take of the pull starter and look at the cog and pull the rope and if the cog pops up then its fine
Jun 28, 2009 | RTO Mini Quads
Feber spare parts
Feber has a help line, they will post the parts to you. Helps if you have the instruction book the part numbers are listed in them. Tel 0870 2406463
Jun 16, 2009 | Toys
Feber Roadster Waverazor Battery Powered Childrens Car Logo
188 people viewed this question
Top Feber Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Feber Toy Expert? Answer questions, earn points and help others
