Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My Amana Side-by_Side SXD26VL is not cooling. The
My Amana Side-by_Side SXD26VL is not cooling. The condenser fan runs, the compresser appears to be running, but neither line is hot or cold, both about room temperature. The evaporator fan is not running, even though it appears to have 115 volts supplied to both sides (?). I thought this was 220V, but the motor says 115V so right there I see an issue. I removed the evaporator fan and at 115V, it worked, but I'm not sure how well.
If the compressor was running correctly, I would have expected to see frost on the evaporator, right?
    Sergeant:
    Champion:
  • 255 Answers
Clean cond coil at back of unit.
check amp draw on the compressor wires.
Posted on Sep 24, 2009
Amana side by side freezer not freezing but is cool fridge side appears to be a little warmer both fans are running.....in back and in freezer compartment
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Refrigerators
Our Amana side by side is not cooling very well in the refrigerator or freezer. Stuff at bottom of freezer is frozen, but stuff at top of freezer is melting. Same with the fridge. Stuff at the bottom is...
It sounds like the unit may be "frosted-up" or the circulating fan has stopped running. (regardless of the frost-free system). I have had to take them apart, (the inside rear wall) and defrost behind there. Push the button on the door switches and see if the fans start to run. If they don't start blowing or make squealing noise then you need a new fan(s). So a service call may be in your future unless you want to dive in with a hair dryer and tools. In any case, enjoy eating everything before it spoils.
Dec 05, 2010 | Amana Refrigerators
Side by Side not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Refrigerators
Kenmore side by side refrigerator. Condenser fan
i DONT HAVE A CONDENSER FAN FOR MY FRIDGEDAIRE SIDE BY SIDE REFRIGERATOR. I'm using a regular fan. How can i purchase one
Jun 03, 2010 | Whirlpool ED2FHSS Side by Side...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Runs but doesn't cool
An Amana SxS has 3 motors. The evaporator fan motor in the freezer (common failure in Amana's), condenser fan motor behind the cover on the bottom back of the machine, and lastly, the compressor itself.
If just one of these works, it could be claimed the machine is running.
If there is no frost built up on the rear panel of the freezer compartment (defrost system failure), and if both fans are running, and no frost exists on the back panel of the freezer compartment, then it would a problem with the compresser, and would need either a new start kit, or possibly a new compressor. This last part should be handled by a pro.
Oct 24, 2009 | Amana Refrigerators
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana ASD 2620HRZ side by side not cooling at all!
if all of that is running your ref. should be cooling.can you hear your compressor running?or can you hear it run for a few seconds and click.If you hear a clicking noise the relay to compressor has gone bad,if it is running then you have a leak in the sealed system.
Mar 08, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
431 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
