Question about Emerson Fans 300 Heating & Cooling Thermostat
Vulcan Freeloader water heater draining at bottom
Hi. My Vulcan Freeloader has started draining a lot of water from a small tube at the base. I can hear water running about half way up the unit. Any ideas what this may be, and if there is an easy solution? The model is 69-25 (145litre)
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: Vulcan 300 Freeloader Gas Water Heater
I assume it has a pilot. Try blowing out the pilot area with compressed air or CO2. Then relight the pilot.
Dust can cover the pilot combustion air inlet and cause it to pull away from the safety generator or thermocouple. Its called an oxygen depletion arrangement on some space heaters. I assume your Domestic Water Heater has this setup as well. Even if not the thermocouple is not getting all then heat from the flame. If this doesn't work get back to me here. We'll try 1 more thing.
If this helps you please grade me accordingly. GOOD LUCK
Posted on Mar 04, 2009
heatman101
  • 43501 Answers
SOURCE: has started to drip water from the base of the
If this unit is that old than it is time to replace it. It has lasted longer than many of them do...
Posted on Nov 12, 2009
Vulcan electric hot water heater. I want to know how to drain enough water out in order to replace the relief valve
turn off unit turn off water supply open drain at bottom let water out close drain remove valve
Aug 31, 2017 | Water Water Heaters
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Should our vulcan freeloader drip water from the small pipe, it often blasts steam out....is this normal ?
If you are sure the coolant (antifreeze) that is not diluted with more water than necessary, but if it is diluted should shut off the system and pour new liquid concentrate (antifreeze) and water in a ratio of 1: 1
Nov 03, 2014 | Motorcycles
We are getting a brown colour in our hot water from our Vulcan freeloader (assume this is where its from anyway). Is this a fixable problem or will we need to look at a new unit? The current unit is about...
unfortunately there is no fix other than replacing the tank, it has a lot of rust buildup inside over 18 years, which is a very long time for a hot water tank today.
Aug 30, 2011 | Water Heaters
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Emerson Fans 300 Heating & Cooling Thermostat Logo
162 people viewed this question
Top Emerson Fans Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Emerson Fans Heating and Cooling Expert? Answer questions, earn points and help others
