Question about Philips AJL308 USB/SD radio alarm clock
The same boring white gaps over my slideshow of pictures
Sept 23, 2009 - I have the same problem and i don´t know what to do to fix the problem!!!
    Problem Solver:
  • 9 Answers
Erease the gaps
Posted on Nov 14, 2009
12 hp briggs and Stratton flat head piston ring gap
.010-.012" minimum at the bottom of the bore
max gap is .025" at the bottom of the bore with worn rings
rule of thumb measurement is .003" per inch of bore so a 3" would be no less than .009" gap for rings
air cooled engines need a bigger gap so work on the .012" measurement
Jan 31, 2017 | HP Garden
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Pulsar 150 CC 2008 Model -I forgot to change engine oil for 10 mnths & nw the mechanic say engine got ceased and bore and piston kit has to be changed. How much it cost for both piston kit and bore ?
Hi, Muth* I recommend a big bore kit for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/13496-pulsar-150-rebore-new-kit-180cc.html
Converting Pulsar 150 to 180
CYLINDER KIT PULSAR180 CC ZADON
Bajaj Pulsar 180 DTSi Workshop Manual
Bajaj Pulsar 150 DTS User Manual
Dec 21, 2016 | 2007 Bajaj Pulsar 150
May you give me a diagram to show me how to place the rings proparely on a piston
As per diagram, make sure that compression ring gaps are 180 degrees/opposite each other, also do not put gaps on thrust faces or above/inline with piston rod pin ...
Make sure you have enough ring gap as well, you need 3-4 though per every inch of bore, do this by placing ring into bore, push down about 1 1/2" with piston and check gap with a feeler gauge, if gap is insufficient you will need to file rings ....
Feb 08, 2016 | Cars & Trucks
What is the sizes on new & worn rings on Bajaj RE205 Piston
the size of the ring will be determined by the bore size
so if it is a 3"(75mm) bore the ring will be that size if placed in the bore separate to the piston and pushed square and to the bottom of the bore the ring gap will denote if standard , worn or oversize to standard
new rings in new bores will have a ring gap of around .010"
worn rings will have a larger gap up to .040" and will have sharp edges where the ring lands wear the rings
over size rings in standard bore probably won't even fit in the bore to start with
ring sets are bought in standard size , .010" over size,.020" oversize,.030" oversize,.040" oversize with the oversize equalling the final hone of a machine bore
so if the machine shop bores the cylinder out to .020" oversize then you need .020" oversize rings to maintain the correct ring gap
from experience I have found that if I follow that rule , on measuring the ring gap at the bottom of the bore the ring gap is about .015" or half worn out
I counter this by getting the next size ring .030" and filing the ends of the rings at the gap to obtain the .010" gap This has produced better longer lasting repairs
Jul 27, 2015 | Bajaj Motorcycles
Philips AJL308 USB/SD radio alarm clock Logo
98 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
