Question about SanDisk Sansa E280 MP3 Player
Want to replace existing music on Sansa e280r
Bought Sansa with 90% full of music we don't like. I can sync music from Media player, but want to remove the old first. I tried going to "my computer" and opening the device only to find that the device showed empty. there is over 7 gig on it! Help?
    Problem Solver:
  • 7 Answers
While it is unplugged, go to Settings on the Sans.
Go to USB mode and select MSC
Connect it to computer.
Open device through "My Computer"
Go to Tools
Select Folder Options
Select View Tab
Select Show Hidden Files and Folders
Press OK
You should now see the Music Folder
Delete what you don't want.
Posted on Sep 24, 2009
  • 496 Answers
Ok from windows media player there should be an icon of the mp3 player and an option to format it try that first.
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
Can't delete duplicate tracks!
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Apr 17, 2009 | SanDisk Sansa E280 MP3 Player
Need instructions for sansa e200
Uhm instructions such as like adding music and deleteing
1.To add music you have to have a Media Player and the Usb cord to connect to it. You must drag songs from the Media Player to the right side of the Media Player and then click Ready to Sync
2.To delete music go to My Computer then find the mp3 then it's common sense from there.
Dec 31, 2008 | SanDisk Sansa e250 MP3 Player
Can't download files from Overdrive files
Make sure that either your Rhapsody or Overdrive subscription is still good and resync all files in Windows Media Player.
If that fails, you'll have to start from scratch:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 13, 2008 | SanDisk Sansa E280 MP3 Player
The sansa say its full but its cot nothing on it?
Go ahead and do this, in case the DB is corrupted:
Feb 17, 2008 | SanDisk Sansa e250 MP3 Player
Downloading music
The easiest way to do it is to use windows media player...open up your windows media player and it F3 then add all your files to your library,,,then hit the sync tab..drag the songs your want to add to your mp3 player under the sync list...then just hit sync when you finish
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
Will not let me syncrhonize music to my e280r player
Your songs are in the wrong format - expired DRM license or expired music svc - convert them all to Mp3 format and you will be fine
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 26, 2007 | SanDisk Sansa E280 MP3 Player
Some songs sound lifeless on my e280r
There are many settings in Windows Media Player for Ripping music. Make sure yours are set to WMA with 192kbps or higher..
Windows Media Player>Tools>Options>Rip Music (Copy CD).
Best of Luck.
Oct 14, 2007 | SanDisk Sansa E280 MP3 Player
E280r MP3 player wont sync songs!
If your device is getting too close to its capacity, it will effect the menu on the device. You need at least 6-10MB of free space for the "music database". If thats not it, one or more of your files may be corrupt. To resolve this, you should format the device to delete all the music, then transfer it back to the player. To format, right click on the device under My Computer and select format. Please add to the question if that didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
139 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
