Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
When copying the machine leaves black lines down the copied sheet
  • HP Expert
  • 217 Answers
Clear glass, change cartridge
Posted on Sep 24, 2009
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
Black line
Open top and clean the scanner glass
Jun 17, 2010 | HP 640 Inkjet Fax Machine
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Toner banding down the sheets
Need more info.... Is it pitch line accross the page the whole page or banding on the front or back side of the copies or is it black streaks down the page?
Sep 09, 2008 | Canon imageRUNNER 8500 Copier
Copying problem kyocera mita 3530
You did not specify how much of it it is NOT copying or left off.
Depends on how close to the end it is copying.
Try this make a copy of the ceiling ( open top with no documents and copy) it will give you a black sheet of paper, compare it to your copy, there is a margin of white around the black area this is because :
1- makes sure the toner is falling on the sheet
2- leaves enough room to clear out of the fuser.
Is your print falling in the white area? if so it can be adjusted but there has to be a margin of white around the paper. or it will cause jamming.
Good luck
Nov 15, 2007 | Office Equipment & Supplies
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
151 people viewed this question
Seeker5211
Seeker5211
