Question about GE Refrigerators
GE PSS25MGMCAA refrigerator - Bad circuit board??
I have a GE PSS25MGMCAA refrigerator. I think the circuit board is bad. The fans run, but not the compressor. Based on one of the posts on this site, I jumped the COM and Line terminals and the compressor ran. I also notice on the back side of the circuit board, one of the compressor solder terminals is slightly black. I suspect the board is bad. Do you agree? Is it possible just to replace the compressor relay on the board? I don't want to burn up a new board, does this sound like just a bad board/relay, or do you think something else caused the board/relay to fail? Thanks for any help you may offer. Jim
  • GE Master
  • 1,606 Answers
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Posted on Sep 24, 2009
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | GE Refrigerators
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Oct 19, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
My frig is starting to send a sound that is similar to wind blowing (I guess from the motor)
The board that runs the functions of your refrigerator is going bad. The fan is pulsating. Slowing down and speeding up. The noise will eventually go away and the fan will stop running and you will think the fan is bad but it is the board. wr51x10656 at about a cost of 160. to 180.00. Easy to do your self but follow instructions that come with board. It is located on the back of the refrigerator behind a metal plate. Good luck and thanx for using fixya.
Feb 27, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My ge refrigerator will not run. Both the
you will need to replace the mother board located behind a removable access panel on the rear lower side by removing 4 screws then unplug old and plug in new mother board,this board contains all the relays that control all the equipment functions
Jan 09, 2010 | Refrigerators
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
The circuit board is making a clicking noise... I
Sounds like you have a GE side by side, replace the mother board. Common problem. Once you replace then check to make sure the evap fan is running and condenser fan are working.
Sep 30, 2009 | Refrigerators
Evap fan wont run can it be tested for bad board
Using a little 9 volt square battery , unplug the fan motor and connect the battery to the motor . ( fan runs on low voltage dc ) . If the fan runs , board is bad , if not , then motor is bad .
Jul 17, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
428 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
