Question about LG RUMOR Cellular Phone
I just had the same problem
I turned it off and removed the battery for 5 mins. and it fixed it.
My phone screen is frozen. I receive incoming calls but can't answer them. Phone battery is not removable. How do I fix this?
Try To kill the battery in the phone and once it is dead try to turn it on a couple times with out the charger plugged in then plug in the charger for about 5 min while the phone is off and try to turn it on again and see what happens.
Apr 29, 2016 | Cell Phones
WARNING !! please clear CMOS if system no display after overclocking. how to fix it ?
remove the cmos battery for sometime (min 5 mins) and try again. If it still occurs then search for the CLR_CMOS jumper on the motherboard. switch positions and check. remove the jumper and check also. it should work. most cases removing the cmos battery works
Apr 08, 2013 | Biostar G41-M7 Motherboard - Socket 775,...
Always restarting
Hi Reynaldo,
Please find the below steps to resolve this issue
Step 1: Turn on the mobile
Step 2: After 2 to 3 mins, switch it off
Step 3: Now remove the battery
Step 4: Remove the Memory Card
Step 5: Remove the Sim Card
Step 6: Now hold the Turn on/off button for 10 secs
Step 7: Take the hand from the button and insert the sim and battery to the mobile, please dont insert the Memory Card
Step 8: Now hold the Turn on/off button for 5 secs continuously
Step 9: Take the hand from the Turn on/off button
Step 10: Leave the mobile, for 10 to 15 mins, after that please insert the Memory Card
Step 11: Now check the status of the Mobile
Thanks for contacting Fixya
Regards,
Aysaam
Apr 02, 2011 | Nokia 5530 XpressMusic Smartphone
My cellphon keep on turning on and off over n over again
Try resetting the cell phone by removing the battery, wait for 5 mins, insert the battery and switch on your cell phone.
Hopefully this will fix your problem.
Mar 10, 2011 | Computers & Internet
My cell appears a blank screen when i switch on it
Soft reset the phone. Remove the battery while the phone is ON. Leave the battery out for 5 mins. Then turn it back on.
If the same problem occur, send the phone to the reseller or to the manufacturer for repair. Firmware upgrade might fix the problem.
Thank you!
Sep 20, 2010 | Cell Phones
My cell phone restart himself after 5 min how can
> try to removed the battery and press and hold the power button for one minute,connect the batter agin check if its still the same,if yes,contact local tech have them check the mainboard
Jun 13, 2010 | Computers & Internet
Phone wont turn on after i did a master reset to fix a phone memory capacity problem
remove the battery for 5 mins and put it back. connect the charger to it and power on. it should start normally.
Feb 24, 2010 | Samsung Memoir SGH-T929 Cell Phone
Message PLEASE TURN CAMERA OFF THEN ON AGAIN
Sometimes this message appears when force has been applied to the lens. Here are some things to try. Go into the setup menu and find "reset" to reset the camera. If that doesn't work, remove the card and battery...press all the buttons...insert the card and then the battery. You may have a lens problem that can only be repaired at a service facility.
Aug 13, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
The ringer won't stop ringer
remove the battery leave it out for about 5 mins and put it back in
Jan 17, 2009 | Motorola Mobility ROKR E8 Cellular Phone
No LCD display
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Pentax Optio S4 Digital Camera
LG RUMOR Cellular Phone Logo
66 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
