Question about Sony KV-35S40 TV
Mitsubishi tv model cs35405
Hi, our older tv was working fine until the cable company cut off our service, now we have sound but no picture on our tv, even when we use the dvd or vhs. there is nothing appearing on the TV not even the information in the corner to tell you what chanel your on or input your using ? what could be the problem ?
  • brenfogarty Dec 15, 2007
    that dosent tel me much though, how do i go about the repair , or is it a job for a pro
If it is the loss of filiment voltage,you will see no glow on back of pic. tube. if no glow check tube socket hi and h2 connections for poor solder. also check flyback connections hi and h2.
Posted on Dec 16, 2007
It sounds like you might have lost one of a number of things that cause sound but no picture . one which is common is loss of filiment voltage to the crt
Posted on Dec 15, 2007
I have an older Mitsubishi TV, model VS-50605, that has been giving me problems. I am not able to consistently get a picture and/or sound through cable. All my other inputs work properly. I can play my...
I've suspect a loose connection on your unit. I would advice you to check the cable wire for bad connection. Make sure that you have a good source of signal from your cable provider. Bad solder joints on the tuner section is also to consider but the problem is, this is internal, If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in there if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you. Have a nice day!
Feb 17, 2011 | Mitsubishi VS-50605 50" Rear Projection...
I have a 4 year old Mitsubishi WD-57831. Lately, when connected to my cable DVR via a HDMI, the picture flashes on and off and some stations don't come in at all. I changed the cable box 4 times, changed...
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Aug 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I subscribe to basic cable, the TV has been working fine for a year, however now some channels have no sound at all, picture is fine but no sound. Wondering if the problem is with the TV or cable...
hi, if most of your channels have audio on it and some dont have, there is no problem with your tv, it is your cable company that has problem. The best thing is to give them a call so that they could do somethin about it. Hope this helps, goodluck!
Jun 11, 2010 | Vizio SV470XVT 47 in. LCD TV
I have a black screen. Cable company says I have
This is a common problem with Cable companies when they update their firmware. This makes the two incompatible. You can try going onto www.samsung.com and look for firmware updates for your model. Follow the instructions provided. If this does not work then you have a bad cable box. Cables companies are notorious for blaming the tv. Don't let them fool you. Stand your ground and insist on them correcting the problem.
Apr 15, 2010 | Samsung LN-T3253H 32 in. LCD Television
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
No picture or sound
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Sony KV-35S40 TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
