Question about KitchenAid KSRS25IL Side by Side Refrigerator
KSRS25ILWH83, Kitchenaid manufacturered 10/03. Is hs been making clicking sounds for about 5 days. They are not constant and may be many hours apart. When they happen they click, click again and then click a short time after that. Seems like a fan is running before even happens. Seems ilke the compressor is working fine. Would this be something to do with the defrost cycle? I'm not able to find a manual on your site. Is there a diagnositics chart which one could use to determine the problem? Saw one for a different model. Right now I'm not able to detect any cooling issues. The unit is less than six years old. Freezer is full, so I hope it doesn't go out on me. Apparently they don't build them like they used to. Any help would be appreciated. Did pull off the bottom grill and cleaned out the front of the coils. Wish there was a way to area behind them.
    Sergeant:
    Champion:
  • 255 Answers
Sounds like the relay on the defrost timer pcb is going bad. do something with it before it freezes up the evap coil. good catch :)
Posted on Sep 24, 2009
KitchenAid Superba Fridge beeping and clicking on and off
next to the compressor is a relay called a klickson
You can get engineer to replace for about $120 or buy one for about $20
Apr 08, 2014 | KitchenAid Refrigerators
After a few hours my Aprilaire 400 makes a constant clicking sound that won't stop. Is it the solenoid?
This is either the solenoid or a loose low voltage wire. Make sure all the wiring connections are tight, if they are the solenoid if bad and will need to be replaced.
Dec 14, 2012 | Aprilaire 400 Humidifier
Samsung 40inch TV DNIe DVB SRS TruSurroundXT (model:-LE4OTR73BD (R) s) -: power on but no picture or sound and makes a constant clicking sound.
hi the name is matt the problem i am having is the contrast and brightness constantly change by them self and it is near on impossible to see what you are watching was just wondering if there was anyway to sort that or whether im going to have to get a new tv be a big help thanks
Nov 15, 2012 | Televison & Video
Refrigerator is constantly running. Temperature on both freezer and refrige seems to be normal. About a week ago, we pulled everything out of the refrigerator, turned it off for about 5 hours and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 13, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Old kitchenaid mixer makes clicking noise and hook doesn't turn
It sounds like the worm gear has failed. This usually happens when the mixer is overloaded. You will need to take the head apart and check the gears.
Jan 26, 2010 | KitchenAid Food Mixers
Why suction line would ice back
Good day,
Unusual question.
Lots of reasons. You didn't say if it was cooling or cycling off and on.
1. Evaporator fan motor in freezer compartment not running. Doesn't allow the refrigerant to boil off and returns as a liquid.
2. Evaporator coil badly frosted allowing no air flow thru it. Same as #1
3. Runs constantly (days). no demand on system, and once again will not boil off before leaving evaporator.
4. Overcharged. Floods back excess charge.
5. Heat exchanger came apart. The capillary tube is soldered to the suction line to transfer heat from the cap tube to the suction line. Necessary on a refrigerator. Common problem.
Hope this helps
Thanks for using fixYa
Jan 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
3 yr old kitchenaid side by side freezer is cold but fridge is only half cold Yhere was some ice buildup in the middle vent so I unplugged for about 5 hours then plugged back in and the next day same...
Sounds like the defrost timer is not working. There is an approx. 1/2 inch white round shaft with a hole in the middle somewhere either inside the refr. section or on the front bottom frame. If you stick a screwdriver in it and turn it clockwise until it clicks, the compressor will shut off and go into defrost. If it doesn't come on after about an hour, then turn it until it starts. Mark it to see if it turns. It should do one rotation either every day or twice a day. If it's not turning you need a new timer. Cheap and easy.
Aug 02, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fridge running constantly and ice maker wont work
sound like it is low on freon ,,,, if so it runs all the time trying to get cold enough to shut down and it wont make ice ,,,, 1st check to make sure the fan inside is blowing, make sure the temp in freezer part is atleast +5 or below if it hasn't cooled right front the start then thats why they got rid of it ,,,,, leaking freon and it cost to much to repair that problem / larry
Nov 29, 2008 | Refrigerators
KitchenAid KSRS25IL Side by Side Refrigerator Logo
119 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
