Question about Samsung Instinct Cell Phone
Speed dial deleting tab
Tab that says "deleting" under my speed dial
How do I change the speed dial keys that are already programmed?
  1. In the phone, press the Menu key.
  2. Click View Speed Dial List.
  3. Click a contact or phone number.
  4. Perform one of the following actions:
    • To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
    • To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
    • To delete the contact from the speed dial list, click Delete.
Jul 07, 2014 | Mitel Superset 4015 Corded Phone
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
Model #CFX-L3500IF - how do I delete and then add speed dial numbers?
Run the Desktop Manager and, at the speed dial tab,
ADD NEW: Press the New button and complete the fields, then click on OK.
DELETE: Select one of the list and then click on Remove.
Apr 05, 2010 | Canon CFX-L3500 IF Laser Printer
Meridian norstar want to delete and enter new numbers
If you are asking about Outside Auto Dial numbers (a "speed dial" number programmed to a button), follow these steps:
1. Leave the handset down
2. Dial "Feature (star) 1"
3. Press the button to be programmed
4. Enter the "speed dial" number
5. Press button under "OK" on the horizontal display.
The group of 12 buttons on top of an M7310 phone are Dual-Memory buttons, each can hold 2 speed dial numbers. When you press the button, you are using the Lower Memory location. When you press the Shift button (triangle-shaped button on the right) and the a Dual-Memory button, you are using the Upper Memory location. Good Luck!
Sep 28, 2009 | NorStar Meridian M7310 Phone
Can't delete wrong speed dials set up by my wife
You should be able to reassign the speed dials if you want to by going to settings/ speed dials.
Jun 01, 2009 | Nokia 1100
Adding/deleting a new contact to the system directory
You can download the full phone manual from Panasonic here.
Mar 26, 2009 | Panasonic KX-T7630 Corded Phone
Everytime I try to open mail from someone I keep getting an error window that says ERROR 23UVRI on my screen and I cant open anything
Ok, I am guessing that your using AOL?
Here is the first steps to clear the eroor, if this doent work let me know!
Clear the Cache, Cookies and History, Then Reset All Settings in Internet Explorer® Whenever you visit certain Websites, they will store what is known as temporary Internet files and cookies on your computer to identify that Website. Sometimes these temporary Internet files and cookies can cause the issue you are experiencing. Similarly your History list can also be a concern. The more days you have specified for pages to be saved on your history list, the more disk space is used on your computer. You can free up disk space by clearing this list. You can do this manually or you can use the one-click fix.
To manually clear cache, cookies and history, then reset all settings for Internet Explorer® 7.0:
1. Close any Internet browser windows that may be open on your computer.
2. Click the Start button, select All Programs, then click Internet Explorer.
3. In the upper right, click the Tools menu, then click Internet Options.
4. On the General tab, under the Browsing history section, click the Delete button.
5. Under the Temporary Internet Files section, click the Delete files button to clear the cache.
6. Click the Yes button to confirm.
7. Under the Cookies section, click the Delete cookies button, to clear cookies.
8. Click the Yes button to confirm.
9. Under the History section, click the Delete history button to clear history.
10. Click the Yes button to confirm.
11. In the lower right, click the Close button to close the Delete Browsing History window.
12. Click the Security tab, then click the Default level button.
13. Click the Advanced tab, click the Reset button, then click the OK button.
14. Click the Connections tab.
15. Click the LAN Settings button.
16. Under the Proxy server section, click the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) box to clear it, then click the OK button.
17. Under the Dial-up and Virtual Private Network settings section, choose the Never dial a connection option by clicking it, then click the OK button.
To manually clear cache, cookies and history, then reset all settings for Internet Explorer 6.0:
2. Click the Start button, select Programs or All Programs, then click Internet Explorer.
3. Click the Tools menu, then click Internet Options .
4. On the General tab, under the Temporary Internet files section, click the Delete Files button to clear cache.
5. Click the Delete all offline content box to place a check mark in it, then click the OK button for confirmation.
6. Under the Temporary Internet files section, click the Delete Cookies button to clear cookies.
7. Click the OK button to confirm.
8. Under the History section, click the Clear History button to clear history.
9. Click the Yes button for confirmation.
10. Click the Programs tab.
11. Click the Reset Web Settings button.
12. Click the Yes button.
13. Click the Connections tab.
14. Click the LAN Settings button.
15. Under the Proxy server section, click the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) box to clear it, then click the OK button.
16. Under the Dial-up and Virtual Private Network settings section, choose the Never dial a connection option by clicking it, then click the OK button.
Jun 23, 2008 | Computers & Internet
Deleting speed dials on canon fax L800
you should be able to delete the speed dials by lifting the two speed dial pannels and you should get all the configuration butons showing. ress the speed dials button (think its on the middle of the bunch) then delete at bottom right. this should then ask which entry you want to delete ie. entry No 1,2,3,4 ect Hope this helps Cops Pete@wedotoners.com
Sep 24, 2007 | Canon FAX-L800 Plain Paper Laser
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Samsung Instinct Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
