Question about Hobart P660 Stand Mixer
A middle barren broke off
Where can i find the middle baren that is attached to the cover . it broke in half , not allowing the hook to turn
  • toniroma Dec 15, 2007
    please i need help asap
  • 640 Answers
Goto this site http://www.hobartcorp.com/default.aspxe and look for your model under parts
Posted on Dec 16, 2007
Dough hook does not come out
At the point of attachment where the hook is attached to the beater shaft, spray hot soapy water from a window spray bottle on the connection. Very hot water is necessary and eventually the water will seep into the locking space and allow you to twist it off. Repeat several times if it fails the first time around.
Mar 13, 2014 | Kenwood Kmix Kmx51 Stand Mixer
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
My hobart n50 runs on the same speed in 1 and 2 and will not engage in 3 .. also sounds louder than normal..how do you lube?
Hello Ldl,
I understand that you are having a problem with you 5 quart commercial mixer by hobart. The 1 and 2 are the same speed and you are not getting 3. You also would like to know what oil to use in your machine and how to fill the unit.
To answer you speed question first. The speed is adjusted by the bolt located in the middle of the planetary (the part that turns underneath of the head the attachments hook to). If this bolt is tightened all the way up or to lose it will not allow you to achieve all of the speeds. You will have to adjust this screw many times and turn the machine on to check you speeds. Eventually you will achieve all three speeds.
Before I answer how you lube the machine you need to know what kind of lube to use. The gear box uses a 90 weight gear oil and the planetary uses 140 weight gear oil (grease).
Lubing the gear box with top cover:
1. Remove the top of the gear box (the cover)
2. There is a Round plate with three bolts (do not remove) in this plate there is a disc (looks like a cap seal) use a small screw driver to pry this disc out carefully you will have to put it back once you are done lubing the unit.
Lubing with out a top cover:
1. Remove the switch and gear selector (remember position of gear selector)
2. Fill thru whole in side behind plate removed
Lubing planitary:
1. Remove drip ring
2. Remove the planetary (unscrew bolt in middle)
3. Remove key located in the side of shaft
4. Lube and put back together
Thank you for choosing Fixya.com
Justin
Feb 18, 2011 | Hobart N50 Stand Mixer
The flat mixing paddle is stuck in the mixer and can't be removed from the socket. It turns but when I pull it would not come out.
Here's what really happens. The hook has a shaft screwed into it with bayonet fittings that lock into the mixer. The shaft has a locknut where it screws into the hook. If the locknut becomes loose then the shaft can screw in too far making removing from the mixer almost impossible. Try to get a slim wrench onto the locknut and loosen it off enough to allow the hook to be unscrewed. After the hook comes off, move the locknut down the shaft until the whole assembly can be removed from the mixer. Re-attach the shaft to the hook making sure that the exposed portion of the shaft is long enough to allow for easy removal from the mixer. Tighten the locknut and you will never have the problem again.
Oct 20, 2010 | Cuisinart SM-55 Stand Mixer
My DeLonghi DSM800 when running sometimes stop for a second and then starts up again. It also seems to speed up at times and almost sounds like it is skipping a gear or something. Any ideas.
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 03, 2010 | DeLonghi 800 Watts Cucina DSM800 Stand...
In need of a Hobart N50 spiral hook
Hi. Goto globeequipment.com they have an ED hook for your N50.
If this solution has assisted you, please rate it. ricardok45
Apr 06, 2009 | Hobart N50 Stand Mixer
Runs fast for a few seconds , then runs very slow
Jan 06, 2009 | DeLonghi DSM7 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Attachments won't turn
most likely a stripped worm gear if the motor still runs but the attachments/planetary gear won't turn.
Did this happen when mixing a big batch of dough or when something fell in the bowl that shouldn't have?
Dec 16, 2007 | KitchenAid K45SS Classic Stand Mixer
Hobart P660 Stand Mixer Logo
69 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
