Question about Dryers
Popped and then wouldn't start again checked breaker not it
  • 11,896 Answers
There is a bad capacitor in the power supply that is quite common.
Posted on Sep 23, 2009
The A/c and heating unit does not cut on anymore. What could the problem be?
Are you sure you have power? Is it 220? if so double check Circut breaker. If it's popped and pops again when you reset, unplug the unit. Try to reset again, If it pops again when you reset, you have major electrical problem call electrician. If it holds, then you have a major appliance problem that is causing the unit to "pop" the circut breaker. If it's a central unit similar diagnostics, but you can't unplug it. So call your Heating service people. It may just be your thermostat if central system, or more.if the Circut Breaker pops.
Mar 06, 2015 | Heating & Cooling
Microwave pops breaker on start
You probably have either a shorted high-voltage capacitor, or a shorted high-voltage transformer. And there is a 3rd possibility that should be checked first - the so-called "monitor switch" may be stuck in the closed position. There are usually 3 door switches in most microwave ovens, although some have 4. The monitor switch is usually the the one located in the middle of the door latch area.
Feb 15, 2015 | Kenmore Elite Microwave, Model...
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
E442 Fridge Was noisy, now trips mains power :(
Sounds like the compressor is grounded out causing the breaker to trip, but it could also be wiring, but if I recall most things in those type of machines reduce down to 12vdc and that wouldn't blow the breaker.
Jun 03, 2012 | Fisher and Paykel Refrigerators
MOD DBXR463EG3WW I turned the dial to start it, it started and then quit. Wouldn't start again. I checked the breaker, but it was alright. The light has been out in for two weeks. What could be wrong?
The same switch that controls the light also tells the machine that the door is closed.I would check that door switch first. Hope this helps.
Jun 22, 2011 | GE Dryers
Only large flame comes out and fan does not start
Since this is a propane unit, do not turn it back on again without the fan working. First check to see if the unit has a pop out style breaker, reset it if popped. Check to see if you did not trip a breaker at the breaker box.
Dec 01, 2010 | Reddy Portable Forced Air Propane Heater...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Blower motor runs but dies out..
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
