Question about Acer Aspire 5050-3242 Notebook
Mousepad froze in one spot
I've tried restarting it and taking the battery out, but it still doesn't move eventhough the keyboard is working properly. A little help please.
One of my friends had the same problem. From memory, I think it is a common issue on Acer PCs. Basically there is a button (one of the F keys I think) that turns the mouse pad on and off. I think he said the icon on the key did not look like a mouse pad, but if you squintd it kind of did... Try hitting a few of these keys, and I bet it will spring back into life!!
Good luck
Posted on Dec 15, 2007
When typing, cursor jumps backward several spaces
Sounds like your mousepad is ghosting. This means it thinks you're tapping the mousepad as you type, which will make it type exactly where you nlast moved the curser to. First, try cleaning the pad thoroughly with a damp tissue, and dry it well... if that doesn't solve it, you could try adjusting the mousepad sensitivity controls on the control panel. Hope that helps.
Oct 10, 2012 | Acer Aspire 5733Z-4633
Laptop mousepad doesn't work correctly
If it is a new Laptop then I'll not suggest you to open it for cleaning because you'll void the warranty period. You can check for the latest touch pad driver and update it once. it may help you.
Aug 13, 2012 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Hi my name is amyraffan and my dell inspiron 1545 touch pad/ mouse has stopped working completely it wont move and its froze in the same posiition, please help!
there is a button to disable the touchpad near to it. check if you had accidentally clicked on that button which disables your mousepad.
If still problem not solved, then try reinstalling the touchpad device driver alone from the driver cd provided along with your laptop.
I hope this helps you.
Thanks
Sep 19, 2010 | Dell F3534 Touchpad
The scroll bars on the mousepad don't work
Since it is a Laptop you can not just go over to the Scroll Bar. Move the arrow from the mouse over to the scroll bar. Hold on the left key below the mousepad. The scroll bar should turn a differnt color. Move the scroll bar up and down with your finger,using the mousepad.
Oct 16, 2009 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Acer aspire 5710g Keyboard Issue
Sometimes the keyboard connector to the motherboard becomes loose it may workproperly sometimes sometimes it may not, its better take your notebook to some technical person open the notebook there and attached the connector firmly
Sep 12, 2009 | Acer AOpen AW 200 Sound Card
Mousepad Frozen
the acer has a driver and software restore program on your desktop, I suggest you re install the driver for the mouse pad, you may have to use an external usb mouse to do it. try that
Jun 21, 2009 | ASUS Eee PC 1000H Laptop
MOUSEPAD DOESNT WORK! HELP HELP HELP!
Try here.
They have very good support links.
Jun 14, 2009 | Emerson MW8108P Microwave Oven
Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Apr 14, 2009 | Toshiba Satellite A60 Notebook
Laptop Compaq Presario 2700 Keyboard & Mousepad lost at all
I read somwhere that most motherboards have a third layer of conductors laminated in the middle of board.It could be possible that you are shorting out something there. Take the screws out and try it without the heatsink for a minute or so. Most big DUI stores sell plastic screws in their hardware areas. These will work no problem.
Nov 28, 2008 | Computers & Internet
Locked keyboard and mousepad on acer aspire 6920G
Almost same problem: the mouse froze.
Found a nice solution at another website: switch off the pc, unplug the power supply cable AND remove battery. Press "on" switch for 20 seconds. Now re-install battery, plug back power supply cable, and switch on. Worked for me (what exactly worked for me I don't know but hey)
Good luck.
Oct 20, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5050-3242 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
