Question about Cooper Industries Cooper Wiring 2158V 3 Gang 2 Toggle Switch- Duplex Wallplate, Ivory
How to wire 3 switches in a 3 gang box
I'm trying to wire a 3 gang box that has 15 amp power into it which consists of a single pole dimmer switch, a 3 way fan/light switch and a 3 way dimmer switch. I believe i'm to nut all the white together, ground together but not sure about the hot black whether I pigtail it to all the switches or what? a diagram would be fantastic!
  • 864 Answers
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: how to wire 3 switches in a 3 gang box - a5fa64a.gif
Posted on Sep 23, 2009
I replaced a two gang light switch and now only the bathroom light works landing no help
Assuming both switches are single pole...
One black wire from connects breaker connects to each switch.
One black wire from light goes to light
http://waterheatertimer.org/How-to-wire-switches.html#gang
If your switches are 3-way... then re-post new question.
Gene
Water Heater Timers Save Money
Mar 14, 2015 | Electrical Supplies
I need a wiring diagram for a Cooper 6482 dual control
Hi John,
I'm an electrician and can help you with this question.
The *best* way to plan for this fixture is to install a "3-wire" cable (romex, bx, etc.) designated as "14-3" where "14" is the size of the conductors and "3" is the number of insulated conductors. A "three wire" cable consists of 3 insulated conductors (white, black & red) and an uninsulated or bare conductor. Sometimes, you may find that the cable has 4 insulated conductors and instead of a bare conductor it will be covered with green or green with a yellow stripe insulation. This 4th wire is the ground wire (insulated or not). Either type of cable is acceptable for use.
By installing a 3 wire cable, you will not be required to use a "special switch" or an "RF switch" which are often much more expensive to purchase and more involved to install. You can use two independent switches, consisting of a variable dimmer for the light and a speed controller for the fan, simple "snap" or "toggle" switches or any combination of both if you install into a "2 ganged box". If you opt to install a single gang box, your switches will be needed to be on a single strap (often called duplex switches) and your choces for control will become limited - and likely more expensive, too.
If you run a 3 wire cable, you can install your choice of switches, if you install only a 2 wire cable, you will be forced to use special switches or a standard switch and a pull chain on the fixture (this option is only available to you if there is a constant power source at the fixture). It will cost a little more for the 3 wire cable, but it will provide the most flexibility when selecting fans / switches.
I hope this was helpful & good luck!
Feb 26, 2013 | Electrical Supplies
How to you install a Leviton Slide Dimmer with Preset No. IPI06 to a double switch box where one switch controls the ligth fixture over the table(the one I want to connect the dimmer to) and the secon
Hi Velie,
I am an electrician and can help you wire this switch. If I understand correctly, you have a two-gang switch box in the wall. In it, you have two switches installed. One switch is a 3-way type, and is one of two (or more) switches used to control preparation area lighting. The other switch is a single pole type and controls a light over your kitchen table. Right?
If this is correct, remove the double switch wall plate. Let's set aside concerns with the 3-way switch. We have nothing to do to this switch so we will not need to remove it from the box, nor will we need to disconnect it. It works independently of the switch that controls the light over the table.
Remove the switch that operates the light over the table. If it is indeed a single pole switch, it will have just two terminals for wires to connect. It will probably also have indications for ON and OFF on the handle. If installed correctly, flipping the toggle up or pressing the top of the switch will turn the light on. If is a 3-way switch, it will have terminals for 3 wires to connect. One of the terminals will be a dark color from the other two. Additionally, no ON and OFF markings are on the switch handle and the light may turn on in either handle position (depending on the position of other switches controlling the light). With this information, I assume that you have now verified that it is in fact, a single pole switch. Right?
If all is going as expected, then we can continue. Shut off the power. Since a single pole switch has only two wires to connect, this should be fairly easy to do. One terminal should have a single wire that goes to the light over the table. The other terminal should have a wire that is powered all the time. It is very possible that the wire that connects to this terminal is ALSO is connected to the the 3-way switch either directly, or by a short length of wire that has a wirenut to connect several wires together. If you need to verify a connection to the 3-way switch, remove the switch from the box if needed (do NOT disconnect any wires). The wire should be connected to the dark colored terminal screw of the 3-way switch. This would indicate that this wire - and those connected by wire nut to it - is the source of constant power. Carefully fold the wires into the box and re-secure the 3-way switch if you pulled it from the box.
You new switch has a single RED wire and TWO black wires. Twist a wirenut cap on ONE of the black wires (it does not matter which). Remove the wire that was determined to be powered all the time (was also connected to the 3-way's dark colored terminal) from the old switch, and twist it around the dimmer switch's remaining BLACK wire with a wirenut. Disconnect the remaining wire from the old switch and twist it around the dimmer switch's RED wire with a wirenut. Add the dimmer switch's GREEN wire in to the bundle of uninsulated ground wires in the wirenut inside the box. Fold all the wires gently into the box and secure the dimmer to the box. Install the wall plate and turn on the power.
I hope this helped & good luck!
Feb 10, 2012 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
http://waterheatertimer.org/images/Single-pole-switches-in-4-gang.jpg
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
Aug 19, 2011 | Leviton DECORA TWO GROUNDING SWITCHES...
How to connect three gang switch to control three lights, using two 1mm double core
What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
Aug 16, 2011 | Cooper Industries Cooper Wiring 2158V 3...
How do i wire a 3 gang switch
Open following links for images of 3-gang and 4-gang single-pole switches.
With the 4 gang, just subtract one of the switches.
http://waterheatertimer.org/images/despard-500.jpg
If you have a 3-way switch, or outlet in the box, then add a comment with more exact information about what wires you are trying to connect, what color wires you have, and what you have tried so far. This will narrow down the possible answers and speed help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Cooper Industries Cooper Wiring 2158V 3...
Hi, How do you wire a Leviton switch to the next switch in a 4 gang box? Diagram? Thanks! Michael
Switches are not identified.
Single-pole switches are wired differently than 3-way.
Wire colors are not identified. Some boxes have red and black wires that carry power.
Add a comment and fill out details after studying image and reading information.
I am not there, so you can also add a comment and include in-focus photo of your switches that you posted on Flickr.
Following image shows single-pole switches, with typical black and white wires.
No bare copper ground wire is shown. Ground wires connect to green screw.
So your new switch has 2 brass screws. No white wire connects to single-pole switch. One screw will have 1 black wire that goes to light fixture. The other screw will have 1 or 2 black wires that jumper or connect to the other switches as shown in image.
White wires are usually twisted together and covered with wire nut and pushed to back of box.
Upvote the help.
May 21, 2011 | Leviton 15a 120v Sp Switch
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Cooper Industries Cooper Wiring 2158V 3 Gang 2 Toggle Switch- Duplex Wallplate, Ivory  Logo
10,396 people viewed this question
Top Cooper Industries Electrical Supplies Experts
john h
Gene Haynes
obsteiner
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
