Question about Kenmore Cooktops
I have a kenmore induction model # 564.4498511. when i try to turn a burner on i push on then high and all it does is beep and blink. never heats up..and it does it on all burners
3 Suggested Answers
  • 63 Answers
SOURCE: My Kenmore cooktop will not heat properly, all 4
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Posted on Mar 11, 2009
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
How do I fix an Electrolux induction range element that is not at full power?
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
Feb 18, 2015 | Electrolux EW30IS65JS - 30"Electric...
My induction cooktop shows a bunch of numbers and rings when I try to turn it on
http://handymanwire.com/ubbthreads/ubbthreads.php/topics/577805/Kenmore_Induction_Range_Fault_
Nov 29, 2013 | Kenmore Cooktops
Induction cooktop-flashing keypad
Refer to user manual or company support, the keypad is giving you a error message of some sort, and it is dependent on the make and model on what that error message means so by referring to the manual or posting it would further help you in figuring out what the issues
Jan 27, 2012 | Cooktops
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Cooktops Logo
131 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
 Fix Your Board
Fix Your Board
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
