Panasonic dvd-ls91 erro code H03
I'm getting an H03 error code. Do you know how I fix it?
  • 5 more comments
  • Jdel Dec 30, 2007
    What can I do
  • civilwarprod Jan 16, 2008
    I also have the same identical problem....I wonder if the money I spent for this was really worth it...It seems like these things are plagued with problems...
  • megdu_sm Mar 06, 2008
    My panasonic dvd player was also giving me the H03 error. I follwed the other person's advice, and pushed the laser reader to the left, and problem fixed! This saved us from a potentially disastrous road trip with three little ones, thanks!!
  • txccider May 23, 2008
    YES!!!!--my son was thrilled that his dvd player is now working-
    His was stuck far left next to the spindle, I took a small flathead screwdriver
    and clicked it one click put the disc in----Now I'm the hero!
  • CJA23 Aug 13, 2008
    WHEN TRYING TO READ A DISC MY DVD PLAYER DOESN'T SCAN IT GOES TO H03
  • Paul Mattingly Aug 19, 2008
    I have the SPectroniq PD-3000. When I put a dvd in to load, the drawn closes and it gives the "load" prompt for a long time and then gives a "error" reading. On my tv (hdmi) I get a "bad disk" signal. What can I do?>
  • jittos May 18, 2009
    I followed the instruction above.. Its a bit hard to move the reader but must push carefully... Cheers... it really worked for now :)
I experienced the same dreaded H03 error code recently. The fix was simple:
Open the DVD lid. In the center is the black plastic spindle. To the right of the spindle is the laser reader which slides from side to side.
When my player was in error mode, the laser reader was stuck in the far right position on the track. To fix the problem, gently, but firmly push the laser reader to the right until it clicks in to proper position. For mine, I pushed it to the right about an eighth of an inch before it clicked.
Insert a disc, and turn the player on. This should fix the problem, at least it did with mine.
Posted on Feb 02, 2008
  • duckadoo41 Mar 14, 2011
    had to take apart unit and found a small object stucking
    the laser assy.
  • william abbath Nov 13, 2013
    This trick worked wonderfully for me. Mine was really stuck and I had to push/pry to the point of feeling like it would break. It dislodged, went to the far right and has been working perfectly. Thank you for the help!
We encountered Error Code H03 and after seeing many solutions relating this error to a stuck laser reader, I began to check the travel of my laser reader which moves on a threaded spindle track that is only accessible by opening up the back of the DVD player housing.
Open the DVD lid. In the center is the black plastic spindle. To the right of the spindle is the laser reader which moves from side to side.
I unscrewed the many visible screws in the bottom part of the DVD housing and carefully opened it up. you can then see the threaded spindle that moves the laser reader when turned. In my case, the laser reader was jammed after a certain point of travel. I blew high pressure air from a can of compressed air (Dust & Lint Remover for keyboards) all over the vicinity of the laser reader assembly and a broken piece of plastic came out. Happily, the laser reader could travel freely and completely both left and right as I rolled the threaded spindle. To test if the Error H03 problem has been resolved, I replaced the bottom housing and connected the battery to turn the DVD on. Eureka! There was no Error H03 and the unit appeared to work as good as new. I then installed the many screws and declared mission successfully completed. Fortunately, the little broken piece of plastic, which I discarded, doesn't seem to affect any of the DVD's functions, at least up to now.
Posted on May 03, 2009
All I did is follow the advise here...my laser reader next tothe spindle was not stuck to the right but used my finger to move it ..it didnot budge...gave it a couple of strong pushs with my index finger and looks like it unjammed hte guide ot the laser reader and now it works..what i suspect is that the laser reader gets stuck on the guide rails...my suggestestion is to use a compressed ait can to spray aroung the region and keep it clean for future operations..Good luck...
Posted on Dec 22, 2008
Take the bottom part off by taking out all the little teeny tiny screws all over the backside (about 10), take a tiny flat head screwdriver and push it in between the upper and bottom shell, and slowly pry it apart from each other. Once it is opened, it will still be held together by one wide flat (not sure what this was) wire looking thing. There is a middle part (silver and black) that comes separated,It has the lens, spindles, and track for the cd, but still hangs on by more of those wire things (a white and a goldish one) There are two tiny spindles on the underneath, one black, one white if you move one of them w/ a Flathead screwdriver, the other one will roll making the square (looks like a reader with lens) go from side to side. I cleaned the two spindles, first by shooting air into it, then by using the screwdriver to take out some of the gook. I also blew air cleaning the mother board. You can test it by putting it back together aside from the screws and putting in a cd, testing the menus, ff and rewind. If all seems well, it should be fixed. Im not sure if cleaning out the gook, or airdusting it did the job, or it couldve been both, but i have a feeling it was the gook not letting the reader move.
Posted on Jul 29, 2009
  • grommit2 Aug 20, 2011
    We had the problem in the car. Unit about 6 years old so I thought it would be terminal. Took off the back and found a lot of fluff aroung the spindle. Gave it a clean, re-assembled and all looks OK. Took about 10 minutes and seems a fairly low risk fix.
Panasonic DVD-LS91 - Error 03 message. Got the message during a 6 hour flight with 3 year old. Argh! The manual said to take it to the service center.
I moved the laser reader using a flat butter knife - no screwdriver available as instructed on this site. It WORKED! The flight home should go smoother. Thank you.
Posted on Oct 11, 2008
Moved laser head to right. Fixed problem. Thanks so much
Posted on Jun 21, 2008
  • jlotiger Nov 04, 2010
    I just used this advice on my panasonic dvd/cd portable player and it worked immediately!! I had even contacted panasonic and they had me push buttons which didn't work, then told me it would be $140 to repair my unit!!! I found your answer and tried it and it worked!!! Thank you for saving me big bucks!!
Just wanted to thank you for the solution to my H03 problem. The lense must have become stuck to the far left of the spindle. Good job!
Posted on Nov 24, 2010
Thats works to me thanks
Posted on May 06, 2011
Thanks for the solution.  I moved the laser all the way to the right and that did not fix the problem so I moved the the laser all the way to the left.  Still did not fix it so I tried moving the laser back to the right with the power off and it now works.
Posted on Jun 11, 2008
Panasonic dvd-lx95 error code h03
Lube up the slider that the laser slides on (slides in towards the center of disc and back out). Check for any debris that may be present.
Download Panasonic DVD LX95 Manual
Oct 11, 2013 | Panasonic DVD-LX95
H03 Error
This problem is the laser optics in the wrong position.
Try to move it carefully by hand to the left near the spindle.
It may be stuck on the right side.
Please let us know what you see!
Jan 05, 2008 | Panasonic DVD-LX97 Portable DVD Player
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Player will not read. Error code H03 shows up on screen.
Dirty worm gear on laser (dirt or particles got caught not letting the pick up move easy go take apart but be careful many small screws and gears.
Oct 06, 2009 | Panasonic DVD-LS91 Portable DVD Player...
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code h03
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jan 17, 2008 | Panasonic DVD-LS90 Portable DVD Player
Televison & Video Logo
5,185 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
