Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freeze maintains normal temperature but the refrigerator does not. Already checked temperature settings. What could be wrong?
  • Mike Smith
    Mike Smith May 11, 2010
    Check to see if there is frost built up on the inside rear freezer wall . If so , then you have a defrost problem . Also , check the ttop left wall of the refrig section , to feel if any air flow to the refrig section . Reply back to these questions , and a fixya expert will be glad to help .
    Sergeant:
    Champion:
  • 255 Answers
Check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
  • jason king
    jason king Sep 24, 2009
    also check the heating element for proper Resistance.
The temperature is going high and is runing all the time
Hi mh_petrovici - When doors are opened too often or too long, warm air enters the refrigerator causing it to run more or when the room or outside temperature is hot, it is normal for the refrigerator to work longer under conditions. Temperature control may be set too cold (normally found in refrigerator section), set control to warmer setting until refrigerator temperature is satisfactory. Allow 24 hours for temperature to stabilize completely. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Check and see if the condenser is dirty. A dirty condenser blocks air that dissipates the heat that the condenser removes from the unit. Clean the condenser every 6 months and more if you have animals in the house.
Nov 23, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ignis fridge isn't cold enough, and seems unable to maintain a constant temperature. I bought a fridge thermometer to get some accurate data: fridge is typically between 9 - 15 degress c. Generally, a good...
the compressor is acting weird because the fridge might need regasing if the tempreture
uness the fridge controls for the tempreture nside the fridge are buggered and the thermostat
Jul 05, 2008 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Bottom of refrigerator continues to freeze food<already replaced thermostat in refrig section?
Have you checked the refrigerator temperature control setting? It may be set too cold. Try turning the knob up a few numbers.
Feb 27, 2011 | Microwave Ovens
The freezer maintains the temperature, but the refrigirator shows 47 degrees irrespective of the setting.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Amana Refrigerators
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
Refrigerator will not maintain proper temperature
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Apr 19, 2009 | Samsung RS2534 Side by Side Refrigerator
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
146 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
