Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
I have a water leak that goes into control box & then leaks out forming a small icycle It is an IM-6 Ice Maker
  • 986 Answers
Http://sites.google.com/site/sublimeappliancerepair/refrigerator-problem/defrost-info/ice-maker-quit-making-ice-im-secrets
Here is a link to common ice maker problems. Chances are you have a pin hole in the water line. It may also be a leaky water valve which is on that link. also check for a broken ice mold. Best of luck.
Posted on Sep 23, 2009
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Ice is forming at the bottom of the freezer. what could be leaking to cause this?
Is there an ice maker in the freezer? Check it. There could be a leak there. Check the defrost tube. When the freezer goes into defrost, the water has to exit the box through a tube, of some sort.
Aug 16, 2014 | Whirlpool 25.2 cu. ft. Side-by-Side...
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Occasionally the ice cube maker overfills causing the water to fall to the frezzer floor and leaking onto the ground, any suggestions on how to fix this?
Are you sure its the icemaker overflowing? if it is, you will have icycles on all the shelves and the food leading down to the floor of freezer. If you have NO icycles between bucket and floor, you have a clogged defrost drain problem.
If you do have icycles between bucket and floor, you will also have a big block of ice in your ice bucket. without personal inspection, i would advise replacing both the ice maker and the water valve(s)
Mar 18, 2010 | Frigidaire FRS26H5AS Side by Side...
There is a sheet of ice forming in the ice cube tray and a larger one forming on the bottom of the freezer. The GE refrigerator is only 6 months old.
Because the sheet of ice is forming on the ice maker first it leads me to believe the water control valve for the ice maker is leaking water into the ice maker when it should be off. A filter installed before the dual water control valves would also be helpful. If you could find the model number of your refrigerator I would be able to tell you the part number. Sea Breeze
Nov 24, 2009 | GE Refrigerators
The cubes are hollow and keep get stuck when they try dispence
The cubes are hollow? Means not enough water coming in on the fill cycle to fill the metal ice tray (netal form, see solution #2). There should be an adjustment under the end cover, looks like a screw with a spring around it. Look inside the cover and see if the directions are there for adjusting it properly.
Sep 19, 2009 | Whirlpool GD2SHGX Refrigerator
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker is leaking water. Never has worked well takes for ever to spit out ice. Now ice is all over everything in freezer since leaking but will still make some ice. I have had for 2 years/.
Do you have a water softener? This puppy won't work right if you do. ice maker leaking water? Ok lets do the scenario. This fancy ice maker will fill the ice mold in stages according to resistance levels measured by the control inside the IM. I initially will judge resistance in the ice mold and then will call for water. It will again judge for full ice mold by checking resistance. The 3rd attempt will supposedly satisfy the requirements of the ice mold. If the water softener goes into reverse osmosis(that time or the month for water sofeners). Then electrolysis will occur in the ice maker and some different resistance readings from what is built in is read. Oops! overflow of ice maker and weird ice production. Solution. Remove ice maker from the loop. Water softening is good for the clothes but hell on the ice production.
Jun 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
