Question about Brother CS-100-T Computerized Sewing Machine
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
    Problem Solver:
  • 12 Answers
Try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Posted on Nov 21, 2009
The bottom thread keeps bunching up and stalls the machine with the #E6. How can I fix?
Suspect the top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Test your machine.
You can also look in the troubleshooting section of the manual for what the E6 code means.
OR, search for:
Make Model E6
Jul 09, 2017 | Sewing Machines
Error message e6. Needle won't move
Check your owner's manual - troubleshooting section. Sometimes it will show the error codes. Otherwise, search the internet for:
Make + Model + "error code E6"
You can also check with the manufacturer.
Nov 09, 2016 | Sewing Machines
I just purchased the singer 5500/5400 and I keep getting error code C4. I've followed the instructions in the book and some I've found on here with no luck. I'm so frustrated cause I can't even use my new...
Error code C4 is a machine jam. If you had a jam previously, there may be a reset somewhere that resets error codes.
Or, there is possibly a "hairball" of thread inside somewhere that is tripping the jam sensor.
Or, maybe the sensor is not functioning properly.
Mar 16, 2015 | Singer Sewing Machines
How can I free up the thread take up lever whcih is seized in my brother bc2100 sewing machine?
Cut the jammed thread away, carefully. It may only need the thread path cleaned of all loose thread bits after you cut off what's gotten jammed up on the lever.
Jun 29, 2014 | Brother Sewing Machines
I have thread and fabric jamming issues with my Brother CE-4000. It jams and gives the E6 error message. When it's happened before, I could clean out the feed dogs and that whole area, plug it back in and...
have you checked to see if the bobbin is turned in the right direction?
have you checked to see if the top thread has come off the thread take up lever?
if these suggestions don't help then I suggest taking the machine in for a check up.
Aug 03, 2013 | Sewing Machines
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
Oct 01, 2009 | Brother Sewing Machines
Code E6 on Brother CE5000PRW sewing maching
I fought with this machine so much, then felt like a fool. It wasn't threaded properly, and I needed to re-set the tension.
Thanks for being there - if only to vent......
Nov 22, 2008 | Brother Sewing Machines
Brother CS-6000 Sewing Machine - Jam
I have the same problem and found that the bobbin case is scratched. These are quite expensive so I hope yours is something more simple. Keeping the bobbin area clean is also a necessity.
Jul 28, 2008 | Brother CS-6000
Brother CS-100-T Computerized Sewing Machine Logo
605 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
